Here are some screenshots.
events.log
2022-02-25 23:56:30.468 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'serial:serialBridge:4bd7deb941' changed from UNINITIALIZED to INITIALIZING
2022-02-25 23:56:30.785 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'serial:serialBridge:4bd7deb941' changed from INITIALIZING to OFFLINE (CONFIGURATION_ERROR): Port is not known
2022-02-25 23:59:41.979 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'test' received command ON
2022-02-25 23:59:42.012 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'test' changed from NULL to ON
2022-02-26 00:00:25.971 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'serial:serialBridge:4bd7deb941' changed from OFFLINE (CONFIGURATION_ERROR): Port is not known to UNINITIALIZED
2022-02-26 00:00:25.995 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'serial:serialBridge:4bd7deb941' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
2022-02-26 00:00:28.354 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'serial:serialBridge:4bd7deb941' changed from UNINITIALIZED (DISABLED) to INITIALIZING
2022-02-26 00:00:28.645 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'serial:serialBridge:4bd7deb941' changed from INITIALIZING to OFFLINE (CONFIGURATION_ERROR): Port is not known
2022-02-26 00:00:46.054 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'serial:serialBridge:4bd7deb941' changed from OFFLINE (CONFIGURATION_ERROR): Port is not known to REMOVING
2022-02-26 00:00:46.102 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'serial:serialBridge:4bd7deb941' changed from REMOVING to REMOVED
2022-02-26 00:00:46.115 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'serial:serialBridge:4bd7deb941' changed from REMOVED to UNINITIALIZED
2022-02-26 00:00:46.131 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'serial:serialBridge:4bd7deb941' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2022-02-26 02:27:38.774 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'serial:serialBridge:edb52034dc' changed from UNINITIALIZED to INITIALIZING
2022-02-26 02:27:39.010 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'serial:serialBridge:edb52034dc' changed from INITIALIZING to ONLINE
2022-02-26 02:33:16.765 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'SerialBridge_StringData' received command 2,OpenHab,1,1,1
2022-02-26 02:33:16.786 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'SerialBridge_StringData' predicted to become 2,OpenHab,1,1,1
2022-02-26 02:33:16.796 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'SerialBridge_StringData' changed from NULL to 2,OpenHab,1,1,1
2022-02-26 02:33:35.861 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'test' received command 2,OpenHab,1,1,1
2022-02-26 02:33:35.870 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'test' predicted to become 2,OpenHab,1,1,1
2022-02-26 02:33:35.878 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'test' changed from NULL to 2,OpenHab,1,1,1
2022-02-26 02:33:39.149 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'test' received command 2,OpenHab,1,1,1
2022-02-26 02:33:39.181 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'test' predicted to become 2,OpenHab,1,1,1
2022-02-26 02:33:56.218 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'SerialBridge' received command 2,OpenHab,1,1,1
2022-02-26 02:33:56.221 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'SerialBridge_StringData' received command 2,OpenHab,1,1,1
2022-02-26 02:33:56.224 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'SerialBridge_StringData' predicted to become 2,OpenHab,1,1,1
2022-02-26 02:34:02.981 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'SerialBridge' received command 2,OpenHab,1,1,1
2022-02-26 02:34:02.983 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'SerialBridge_StringData' received command 2,OpenHab,1,1,1
2022-02-26 02:34:02.988 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'SerialBridge_StringData' predicted to become 2,OpenHab,1,1,1
2022-02-26 02:35:40.306 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'SerialBridge_StringData' received command 2,OpenHab,1,1,1\n
2022-02-26 02:35:40.312 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'SerialBridge_StringData' predicted to become 2,OpenHab,1,1,1\n
2022-02-26 02:35:40.320 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'SerialBridge_StringData' changed from 2,OpenHab,1,1,1 to 2,OpenHab,1,1,1\n
2022-02-26 02:35:42.259 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'SerialBridge_StringData' received command 2,OpenHab,1,1,1\n
2022-02-26 02:35:42.262 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'SerialBridge_StringData' predicted to become 2,OpenHab,1,1,1\n
2022-02-26 02:35:56.389 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'SerialBridge_StringData' received command 2,OpenHab,1,1,1\r
2022-02-26 02:35:56.392 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'SerialBridge_StringData' predicted to become 2,OpenHab,1,1,1\r
2022-02-26 02:35:56.396 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'SerialBridge_StringData' changed from 2,OpenHab,1,1,1\n to 2,OpenHab,1,1,1\r
2022-02-26 02:36:15.115 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'SerialBridge_StringData' received command 2,OpenHab,1,1,1\r\n
2022-02-26 02:36:15.119 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'SerialBridge_StringData' predicted to become 2,OpenHab,1,1,1\r\n
2022-02-26 02:36:15.123 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'SerialBridge_StringData' changed from 2,OpenHab,1,1,1\r to 2,OpenHab,1,1,1\r\n
2022-02-26 02:36:22.321 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'SerialBridge_StringData' received command 2,OpenHab,1,1,1\r\n
2022-02-26 02:36:22.325 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'SerialBridge_StringData' predicted to become 2,OpenHab,1,1,1\r\n
2022-02-26 02:49:10.891 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'SerialBridge' received command 2,OpenHab,1,1,1\r\n
2022-02-26 02:49:10.893 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'SerialBridge_StringData' received command 2,OpenHab,1,1,1\r\n
2022-02-26 02:49:10.902 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'SerialBridge_StringData' predicted to become 2,OpenHab,1,1,1\r\n
2022-02-26 02:49:28.498 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'test' received command 2,OpenHab,1,1,1\r\n
2022-02-26 02:49:28.502 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'test' predicted to become 2,OpenHab,1,1,1\r\n
2022-02-26 02:49:28.506 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'test' changed from 2,OpenHab,1,1,1 to 2,OpenHab,1,1,1\r\n
2022-02-28 18:21:38.105 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'serial:serialBridge:edb52034dc' changed from ONLINE to OFFLINE (CONFIGURATION_ERROR): Invalid charset
2022-02-28 18:23:00.778 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'serial:serialBridge:edb52034dc' changed from OFFLINE (CONFIGURATION_ERROR): Invalid charset to ONLINE
2022-03-01 05:48:53.739 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'serial:serialBridge:edb52034dc' changed from ONLINE to REMOVING
2022-03-01 05:48:53.745 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'serial:serialBridge:edb52034dc' changed from REMOVING to REMOVED
2022-03-01 05:48:53.758 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'serial:serialBridge:edb52034dc' changed from REMOVED to UNINITIALIZED
2022-03-01 05:48:54.122 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'serial:serialBridge:edb52034dc' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2022-03-01 06:04:08.153 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'serial:serialBridge:5cc0a1e37f' changed from UNINITIALIZED to INITIALIZING
2022-03-01 06:04:08.187 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'serial:serialBridge:5cc0a1e37f' changed from INITIALIZING to UNINITIALIZED (HANDLER_INITIALIZING_ERROR): Illegal character in path at index 0: /dev/ttyUSB0
2022-03-01 06:04:51.113 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'serial:serialBridge:5cc0a1e37f' changed from UNINITIALIZED (HANDLER_INITIALIZING_ERROR): Illegal character in path at index 0: /dev/ttyUSB0 to INITIALIZING
2022-03-01 06:04:51.765 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'serial:serialBridge:5cc0a1e37f' changed from INITIALIZING to ONLINE
2022-03-01 06:10:49.756 [INFO ] [openhab.event.ItemUpdatedEvent ] - Item 'SerialBridge_StringData' has been updated.
2022-03-01 06:18:37.159 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Test' received command ON
2022-03-01 06:18:37.165 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Test' changed from NULL to ON
2022-03-01 17:40:13.760 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Test' changed from NULL to ON
2022-03-01 17:40:13.761 [INFO ] [openhab.event.ItemUpdatedEvent ] - Item 'Test' has been updated.
2022-03-01 17:46:34.719 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Test' received command OFF
2022-03-01 17:46:34.722 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Test' predicted to become OFF
2022-03-01 17:46:34.726 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Test' changed from ON to OFF
2022-03-01 17:54:36.696 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Test' received command 2,OpenHab,1,1,1
2022-03-01 17:54:36.703 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Test' predicted to become 2,OpenHab,1,1,1
2022-03-01 17:54:36.712 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Test' changed from NULL to 2,OpenHab,1,1,1
2022-03-01 17:56:16.086 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Test' received command 2,OpenHab,1,1,1
2022-03-01 17:56:16.090 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Test' predicted to become 2,OpenHab,1,1,1
2022-03-01 18:00:41.704 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Test' received command 2,OpenHab,1,1,1
2022-03-01 18:00:41.714 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Test' predicted to become 2,OpenHab,1,1,1
2022-03-01 21:39:18.957 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Test' received command 2,OpenHab,1,1,1
2022-03-01 21:39:18.964 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Test' predicted to become 2,OpenHab,1,1,1
2022-03-01 21:39:25.662 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Test' received command 2,OpenHab,1,1,1
2022-03-01 21:39:25.665 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Test' predicted to become 2,OpenHab,1,1,1
