sendMail syntax error
(Welf Rogalski) #1
I am new at OpenHAB and tried to use the Mail Action but always get an error.
Example:
sendMail("xxx@t-online.de", “test”, “test”)
Error Message
-bash: syntax error near unexpected token `“xxx@t-online.de”,’
Any hint how to solve this problem?
(CM6.5 H102) #2
Have you configured your mail.cfg file?
(Welf Rogalski) #3
sure:
######################## Mail Action configuration ####################################
The SMTP server hostname
hostname=securesmtp.t-online.de
the SMTP port to use (optional, defaults to 25 (resp. 587 for TLS))
port=587
the username and password if the SMTP server requires authentication
username=xxxxx@t-online.de
password=xxxxxxxx
The email address to use for sending mails
from=xxxxx@t-online.de
set to “true”, if TLS should be used for the connection
(optional, defaults to false)
tls=true
set to “true”, if SSL negotiation should occur on connection
do not use both tls=true and ssl=true
ssl=false
set to “true”, if POP before SMTP (another authentication mechanism)
should be enabled. Username and Password are taken from the above
configuration (optional, default to false)
popbeforesmtp=false
(CM6.5 H102) #4
If all the above is correct try adding a space in the message between the , and " like:
It’s a syntax error and everything else looks good.
(Welf Rogalski) #5
hmmm - there is a space between the , and the " in my sendMail statement.
your sendMail is the same like mine.
(Udo Hartmann) #6
Please, whenever posting code snippets, configurations or logs, put them in code fences. There is a big difference between
and
sendMail("xxx@t-online.de", "test", "test")
and there is no chance to find these errors - or even to eliminate these typos from the list of suspect.
(Welf Rogalski) #7
sorry I am a greenhorn – now with code fences:
(Rossko57) #8
Udo is hinting that you need to pay attention to your quote marks, things that look alike may not work alike
Note the different highlighting colours using code fencing
