Platform information:
- Hardware: Linux 4.19.97-v7+ #1294 SMP Thu Jan 30 13:15:58 GMT 2020 armv7l GNU/Linux
- OS:
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 10 (buster)
Release: 10
Codename: buster - Java Runtime Environment:
openjdk version “1.8.0_212”
OpenJDK Runtime Environment (build 1.8.0_212-8u212-b01-1+rpi1-b01)
OpenJDK Client VM (build 25.212-b01, mixed mode)
Issue of the topic: SInce the upgrade frm 2.5.1 to 2.5.2 I get the following error in my rule
sendTelegram’ is not a member of ‘org.eclipse.smarthome.core.th ing.binding.ThingActions’
and no telegram message is send anymore. I did already a remive of the telegram binding, and reinstalled it, but no luck.
Anyone any idea’s ?
my rule
rule “telegram”
Channel “mqtt:systemBroker:mq:Telegram_Sender” triggered
var msg =receivedEvent.getEvent() ;
logInfo(“Telegram”," "+msg)
val telegramAction = getActions(“telegram”,“telegram:telegramBot:bca61409”)
telegramAction.sendTelegram(msg)
postUpdate(Telegram_Sender,msg);
loggging
2020-02-28 14:43:02.538 [INFO ] [ipse.smarthome.model.script.Telegram] - fred
2020-02-28 14:43:02.542 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule ‘telegram’: ‘sendTelegram’ is not a member of ‘org.eclipse.smarthome.core.t
hing.binding.ThingActions’; line 8, column 7, length 32
