Hi
This strip seem to be not processed right. It seems the old strips behave differently than the new ones
NODE 95 is the old one that is working. Here are the channels you see in OH
NODE 102 isn’t receiving the open closed state (=NULL). Here the channels in OH
2021-10-30 22:25:39.201 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=102, callback=0, payload=00 66 09 71 05 00 00 00 FF 06 17 00 C9 00
2021-10-30 22:25:39.202 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2021-10-30 22:25:39.202 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 102: Application Command Request (ALIVE:DELETE_SUC_ROUTES)
2021-10-30 22:25:39.203 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 102: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2021-10-30 22:25:39.204 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 102: SECURITY not supported
2021-10-30 22:25:39.204 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 102: Received COMMAND_CLASS_ALARM V8 NOTIFICATION_REPORT
2021-10-30 22:25:39.205 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 102: NOTIFICATION report - 0 = 0, event=23, status=255, plen=0
2021-10-30 22:25:39.206 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 102: Alarm Type = ACCESS_CONTROL (0)
2021-10-30 22:25:39.206 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2021-10-30 22:25:39.207 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 102: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2021-10-30 22:25:39.208 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 102: Alarm converter processing NOTIFICATION
2021-10-30 22:25:39.209 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 102: Alarm converter NOTIFICATION event is 23, type OnOffType
2021-10-30 22:25:39.209 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 102: Alarm converter processing NOTIFICATION
2021-10-30 22:25:39.210 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 102: Alarm converter NOTIFICATION event is 23, type OnOffType
2021-10-30 22:25:39.211 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 102: Alarm converter NOTIFICATION event is 23, channel alarm_system is not implemented.
2021-10-30 22:25:39.212 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 102: Alarm converter processing NOTIFICATION
2021-10-30 22:25:39.213 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 102: Alarm converter NOTIFICATION event is 23, type OnOffType
2021-10-30 22:25:39.214 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 102: Alarm converter NOTIFICATION event is 23, channel alarm_access is not implemented.
2021-10-30 22:25:39.214 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 102: Commands processed 1.
2021-10-30 22:25:39.215 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 102: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1a5f55b.
2021-10-30 22:25:39.216 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2021-10-30 22:25:39.218 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-10-30 22:25:39.218 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-10-30 22:26:15.396 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 12 00 04 00 5F 0A 71 05 00 00 00 FF 06 16 00 00 D5 00 F2
2021-10-30 22:26:15.399 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=95, callback=0, payload=00 5F 0A 71 05 00 00 00 FF 06 16 00 00 D5 00
2021-10-30 22:26:15.401 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=95, callback=0, payload=00 5F 0A 71 05 00 00 00 FF 06 16 00 00 D5 00
2021-10-30 22:26:15.401 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2021-10-30 22:26:15.402 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 95: Application Command Request (ALIVE:UPDATE_NEIGHBORS)
2021-10-30 22:26:15.403 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 95: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2021-10-30 22:26:15.403 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 95: SECURITY not supported
2021-10-30 22:26:15.404 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 95: Received COMMAND_CLASS_ALARM V4 NOTIFICATION_REPORT
2021-10-30 22:26:15.404 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 95: NOTIFICATION report - 0 = 0, event=22, status=255, plen=0
2021-10-30 22:26:15.405 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 95: Alarm Type = ACCESS_CONTROL (0)
2021-10-30 22:26:15.406 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 95: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2021-10-30 22:26:15.406 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 95: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2021-10-30 22:26:15.407 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 95: Alarm converter processing NOTIFICATION
2021-10-30 22:26:15.408 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 95: Alarm converter NOTIFICATION event is 22, type OpenClosedType
2021-10-30 22:26:15.408 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 95: Updating channel state zwave:device:7175b6a970:node95:sensor_door to OPEN [OpenClosedType]
2021-10-30 22:26:15.409 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 95: Alarm converter processing NOTIFICATION
2021-10-30 22:26:15.410 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 95: Alarm converter NOTIFICATION event is 22, type OnOffType
2021-10-30 22:26:15.415 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 95: Commands processed 1.
2021-10-30 22:26:15.416 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 95: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@f041d6.
2021-10-30 22:26:15.417 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2021-10-30 22:26:15.420 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2021-10-30 22:26:15.422 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-10-30 22:26:15.423 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-10-30 22:26:19.451 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 12 00 04 00 5F 0A 71 05 00 00 00 FF 06 17 00 00 CD 00 EB
2021-10-30 22:26:19.453 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=95, callback=0, payload=00 5F 0A 71 05 00 00 00 FF 06 17 00 00 CD 00
2021-10-30 22:26:19.455 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=95, callback=0, payload=00 5F 0A 71 05 00 00 00 FF 06 17 00 00 CD 00
2021-10-30 22:26:19.455 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2021-10-30 22:26:19.456 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 95: Application Command Request (ALIVE:UPDATE_NEIGHBORS)
2021-10-30 22:26:19.457 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 95: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2021-10-30 22:26:19.457 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 95: SECURITY not supported
2021-10-30 22:26:19.458 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 95: Received COMMAND_CLASS_ALARM V4 NOTIFICATION_REPORT
2021-10-30 22:26:19.459 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 95: NOTIFICATION report - 0 = 0, event=23, status=255, plen=0
2021-10-30 22:26:19.459 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 95: Alarm Type = ACCESS_CONTROL (0)
2021-10-30 22:26:19.460 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 95: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2021-10-30 22:26:19.461 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 95: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2021-10-30 22:26:19.461 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 95: Alarm converter processing NOTIFICATION
2021-10-30 22:26:19.462 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 95: Alarm converter NOTIFICATION event is 23, type OpenClosedType
2021-10-30 22:26:19.463 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 95: Updating channel state zwave:device:7175b6a970:node95:sensor_door to CLOSED [OpenClosedType]
2021-10-30 22:26:19.464 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 95: Alarm converter processing NOTIFICATION
2021-10-30 22:26:19.464 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 95: Alarm converter NOTIFICATION event is 23, type OnOffType
2021-10-30 22:26:19.465 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 95: Commands processed 1.
2021-10-30 22:26:19.466 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 95: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1502d90.
2021-10-30 22:26:19.467 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2021-10-30 22:26:19.468 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2021-10-30 22:26:19.468 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-10-30 22:26:19.469 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-10-30 22:26:30.492 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 65: Polling...
2021-10-30 22:26:30.494 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 65: Polling deferred until initialisation complete
if uploaded to the zwave viewer this info isn’t even shown
look at the logs above saying “channel alarm_system is not implemented.”
Here is the documentation of the device: Strips Guard 700 - Sensative
Our database entry for the device at OpenSmartHouse Z-Wave Device Database has the the following command classes which includes the notification, so I think we are good here, aren’t we?
The notification events are as follows
should that map to parameters in our database?
So how do we have to map the following items in our database?
Cheers
Stefan
