My Sensebox ID is 5d80ec6d953683001a9a8af7, the file follows, sorry, they do not allow me to attach as a file.
2020-01-24 14:20:09.190 [WARN ] [org.apache.karaf.shell.ssh.SshUtils ] - Configured cipher ‘aes256-ctr’ not available
2020-01-24 14:20:09.290 [WARN ] [org.apache.karaf.shell.ssh.SshUtils ] - Configured cipher ‘aes192-ctr’ not available
2020-01-24 14:20:13.076 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to ‘Europe/Berlin’.
2020-01-24 14:20:13.105 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to ‘50.51828,7.29303’.
2020-01-24 14:20:13.113 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to ‘de_DE’.
2020-01-24 14:20:13.116 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Measurement system set to ‘SIUnits’.
2020-01-24 14:20:24.576 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘netatmo.items’
2020-01-24 14:20:24.920 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘airquality.items’
2020-01-24 14:20:25.112 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘pollen.items’
2020-01-24 14:20:25.218 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘sensebox.items’
2020-01-24 14:20:25.269 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘pegel.items’
2020-01-24 14:20:25.307 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘wmr.items’
2020-01-24 14:20:25.378 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘dwdunwetter.items’
2020-01-24 14:20:25.576 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘openweathermap.items’
2020-01-24 14:20:27.081 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘_default.sitemap’
2020-01-24 14:20:27.086 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model ‘_default.sitemap’ is either empty or cannot be parsed correctly!
2020-01-24 14:20:27.146 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘airquality.sitemap’
2020-01-24 14:20:27.182 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘wmr.sitemap’
2020-01-24 14:20:27.212 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘pegel.sitemap’
2020-01-24 14:20:27.323 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘pollen.sitemap’
2020-01-24 14:20:27.391 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘sensebox.sitemap’
2020-01-24 14:20:27.436 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘openweathermap.sitemap’
2020-01-24 14:20:27.487 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘netatmo.sitemap’
2020-01-24 14:20:27.553 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘dwdunwetter.sitemap’
2020-01-24 14:20:33.699 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2020-01-24 14:20:36.486 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.178.29:8080
2020-01-24 14:20:36.513 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.178.29:8443
2020-01-24 14:20:37.899 [TRACE] [sebox.internal.SenseBoxAPIConnection] - Headers: {User-Agent=openHAB / senseBox binding 2.5.1}
2020-01-24 14:20:38.200 [INFO ] [nhab.binding.wmr.internal.WmrBinding] - Update WMR Binding configuration …
2020-01-24 14:20:38.318 [INFO ] [b.core.service.AbstractActiveService] - HTTP Refresh Service has been started
2020-01-24 14:20:38.230 [ERROR] [ome.core.thing.link.ThingLinkManager] - Exception occurred while informing handler: null
at org.openhab.binding.dwdunwetter.internal.data.SeverityComparator.compare(SeverityComparator.java:24) ~[?:?]
at org.openhab.binding.dwdunwetter.internal.data.SeverityComparator.compare(SeverityComparator.java:1) ~[?:?]
at java.util.TimSort.countRunAndMakeAscending(TimSort.java:360) ~[?:1.8.0_65]
at java.util.TimSort.sort(TimSort.java:220) ~[?:1.8.0_65]
at java.util.Arrays.sort(Arrays.java:1438) ~[?:1.8.0_65]
at java.util.List.sort(List.java:478) ~[?:1.8.0_65]
at java.util.Collections.sort(Collections.java:175) ~[?:1.8.0_65]
at org.openhab.binding.dwdunwetter.internal.data.DwdWarningsData.refresh(DwdWarningsData.java:196) ~[?:?]
at org.openhab.binding.dwdunwetter.internal.DwdUnwetterHandler.refresh(DwdUnwetterHandler.java:73) ~[?:?]
at org.openhab.binding.dwdunwetter.internal.DwdUnwetterHandler.handleCommand(DwdUnwetterHandler.java:59) ~[?:?]
at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.channelLinked(BaseThingHandler.java:191) ~[?:?]
at org.eclipse.smarthome.core.thing.link.ThingLinkManager.lambda$0(ThingLinkManager.java:267) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_65]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_65]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_65]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:1.8.0_65]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:1.8.0_65]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:1.8.0_65]
at java.lang.Thread.run(Thread.java:745) [?:1.8.0_65]
2020-01-24 14:20:38.249 [ERROR] [ome.core.thing.link.ThingLinkManager] - Exception occurred while informing handler: null
2020-01-24 14:20:38.247 [ERROR] [ome.core.thing.link.ThingLinkManager] - Exception occurred while informing handler: null
2020-01-24 14:20:38.245 [ERROR] [ome.core.thing.link.ThingLinkManager] - Exception occurred while informing handler: null
2020-01-24 14:20:38.233 [ERROR] [ome.core.thing.link.ThingLinkManager] - Exception occurred while informing handler: null
2020-01-24 14:20:38.447 [DEBUG] [box.internal.handler.SenseBoxHandler] - Start initializing!
2020-01-24 14:20:38.603 [DEBUG] [box.internal.handler.SenseBoxHandler] - Thing Configuration sensebox:box:5ae77940 initialized 5d80ec6d953683001a9a8af7
2020-01-24 14:20:38.613 [DEBUG] [box.internal.handler.SenseBoxHandler] - Refreshing data for box 5d80ec6d953683001a9a8af7, scheduled after 300 seconds…
2020-01-24 14:20:38.646 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
at org.openhab.binding.sensebox.internal.handler.SenseBoxHandler.lambda$1(SenseBoxHandler.java:143) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:1.8.0_65]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) ~[?:1.8.0_65]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) ~[?:1.8.0_65]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) ~[?:1.8.0_65]
2020-01-24 14:20:38.736 [ERROR] [ome.core.thing.link.ThingLinkManager] - Exception occurred while informing handler: null
at org.openhab.binding.sensebox.internal.handler.SenseBoxHandler.handleCommand(SenseBoxHandler.java:119) ~[?:?]
2020-01-24 14:20:38.698 [ERROR] [ome.core.thing.link.ThingLinkManager] - Exception occurred while informing handler: null
2020-01-24 14:20:38.681 [ERROR] [ome.core.thing.link.ThingLinkManager] - Exception occurred while informing handler: null
2020-01-24 14:20:38.667 [ERROR] [ome.core.thing.link.ThingLinkManager] - Exception occurred while informing handler: null
2020-01-24 14:20:38.810 [DEBUG] [box.internal.handler.SenseBoxHandler] - Thing sensebox:box:5ae77940 initialized UNKNOWN
2020-01-24 14:20:38.657 [ERROR] [ome.core.thing.link.ThingLinkManager] - Exception occurred while informing handler: null
2020-01-24 14:20:38.755 [ERROR] [ab.binding.wmr.internal.HIDConnector] - An IO exeption has occured while connecting!
java.io.IOException: Could’nt open weather station HID device
at org.openhab.binding.wmr.internal.HIDConnector.connect(HIDConnector.java:92) ~[bundleFile:?]
at org.openhab.binding.wmr.internal.HIDConnector.run(HIDConnector.java:206) [bundleFile:?]
2020-01-24 14:20:38.795 [ERROR] [ome.core.thing.link.ThingLinkManager] - Exception occurred while informing handler: null
2020-01-24 14:20:41.043 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2020-01-24 14:20:41.303 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
2020-01-24 14:20:41.834 [INFO ] [openhab.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2020-01-24 14:20:49.567 [TRACE] [sebox.internal.SenseBoxAPIConnection] - Fetched Data: {"_id":“5d80ec6d953683001a9a8af7”,“createdAt”:“2019-09-17T14:23:41.064Z”,“updatedAt”:“2020-01-24T13:19:58.210Z”,“name”:“Bad Breisig Rheintalstrasse”,“currentLocation”:{“type”:“Point”,“coordinates”:[7.293334,50.518311,62],“timestamp”:“2019-09-17T14:37:45.042Z”},“exposure”:“outdoor”,“sensors”:[{“title”:“Temperatur”,“unit”:“°C”,“sensorType”:“HDC1080”,“icon”:“osem-thermometer”,"_id":“5d80ec6d953683001a9a8afe”,“lastMeasurement”:{“value”:“2.35”,“createdAt”:“2020-01-24T13:19:58.204Z”}},{“title”:“rel. Luftfeuchte”,“unit”:"%",“sensorType”:“HDC1080”,“icon”:“osem-humidity”,"_id":“5d80ec6d953683001a9a8afd”,“lastMeasurement”:{“value”:“81.43”,“createdAt”:“2020-01-24T13:19:58.204Z”}},{“title”:“Luftdruck”,“unit”:“hPa”,“sensorType”:“BMP280”,“icon”:“osem-barometer”,"_id":“5d80ec6d953683001a9a8afc”,“lastMeasurement”:{“value”:“1018.39”,“createdAt”:“2020-01-24T13:19:58.204Z”}},{“title”:“Beleuchtungsstärke”,“unit”:“lx”,“sensorType”:“TSL45315”,“icon”:“osem-brightness”,"_id":“5d80ec6d953683001a9a8afb”,“lastMeasurement”:{“value”:“1004.00”,“createdAt”:“2020-01-24T13:19:58.204Z”}},{“title”:“UV-Intensität”,“unit”:“μW/cm²”,“sensorType”:“VEML6070”,“icon”:“osem-brightness”,"_id":“5d80ec6d953683001a9a8afa”,“lastMeasurement”:{“value”:“50.62”,“createdAt”:“2020-01-24T13:19:58.204Z”}},{“title”:“PM10”,“unit”:“µg/m³”,“sensorType”:“SDS 011”,“icon”:“osem-cloud”,"_id":“5d80ec6d953683001a9a8af9”,“lastMeasurement”:{“value”:“27.30”,“createdAt”:“2020-01-24T13:19:58.204Z”}},{“title”:“PM2.5”,“unit”:“µg/m³”,“sensorType”:“SDS 011”,“icon”:“osem-cloud”,"_id":“5d80ec6d953683001a9a8af8”,“lastMeasurement”:{“value”:“18.20”,“createdAt”:“2020-01-24T13:19:58.204Z”}}],“model”:“homeV2WifiFeinstaub”,“lastMeasurementAt”:“2020-01-24T13:19:58.204Z”,“loc”:[{“geometry”:{“type”:“Point”,“coordinates”:[7.293334,50.518311,62],“timestamp”:“2019-09-17T14:37:45.042Z”},“type”:“Feature”}]}
2020-01-24 14:20:49.642 [TRACE] [sebox.internal.SenseBoxAPIConnection] - =================================
2020-01-24 14:20:49.647 [DEBUG] [box.internal.handler.SenseBoxHandler] - About to determine quantity for 27.30 / µg/m³
2020-01-24 14:20:49.647 [DEBUG] [box.internal.handler.SenseBoxHandler] - About to determine quantity for 18.20 / µg/m³
2020-01-24 14:20:49.651 [DEBUG] [box.internal.handler.SenseBoxHandler] - About to determine quantity for 2.35 / °C
2020-01-24 14:20:49.647 [DEBUG] [box.internal.handler.SenseBoxHandler] - About to determine quantity for 81.43 / %
2020-01-24 14:20:49.653 [DEBUG] [box.internal.handler.SenseBoxHandler] - State: ‘18.20 µg/m³’
2020-01-24 14:20:49.653 [DEBUG] [box.internal.handler.SenseBoxHandler] - State: ‘27.30 µg/m³’
2020-01-24 14:20:49.656 [DEBUG] [box.internal.handler.SenseBoxHandler] - State: ‘2.35 °C’
2020-01-24 14:20:49.656 [DEBUG] [box.internal.handler.SenseBoxHandler] - About to determine quantity for 1018.39 / hPa
2020-01-24 14:20:49.658 [DEBUG] [box.internal.handler.SenseBoxHandler] - State: ‘81.43’
2020-01-24 14:20:49.661 [DEBUG] [box.internal.handler.SenseBoxHandler] - State: ‘1018.39 hPa’
2020-01-24 14:20:49.683 [DEBUG] [box.internal.handler.SenseBoxHandler] - Command received for an unknown channel: lastReported#luminanceLastReported
2020-01-24 14:20:49.725 [DEBUG] [box.internal.handler.SenseBoxHandler] - About to determine quantity for 1018.39 / hPa
2020-01-24 14:20:49.728 [DEBUG] [box.internal.handler.SenseBoxHandler] - State: ‘1018.39 hPa’
2020-01-24 14:20:49.996 [DEBUG] [box.internal.handler.SenseBoxHandler] - Command received for an unknown channel: measurements#luminance
