No the Key is you authentication.
You shouldent need to enter anything else in.
You have a working bridge
Goto
Click on in the bottom right corner
Then select the sensibo binding
Click
It should show up under discovered things that you can click on and add as a new thing
Perfect! Found it. Thanks James, excellent outcome. Looking at the code, the scan found it and used the MAC address all in upper case as the last characters in the UID and in the macAddress field.
Funny - small differences but it works really well now.
Here’s what the scan code looks like:
UID: sensibo:sensibosky:sensibobridge:[Redacted the MAC address all in upper with no colons]
label: Sensibo skyplus Living Room
thingTypeUID: sensibo:sensibosky
configuration:
->(i.e. indent by two spaces) macAddress: [Redacted the MAC address all in upper with no colons]
bridgeUID: sensibo:account:sensibobridge
thanks for the widget,
But only these work in a widget
I checked the thing and the items, everything is fine
Did you Create equipment from thing
This way it sets all the item names correctly.
Or it did when I did it last year.
Can you send me a list of your item names
i did Create equipment from thing
Thanks for posting pic I see the problem as I created the items in 3.0.0 version of binding.
I just made the widget I didn’t develop the binding. The binding has been updated so now its TargetTemperature not targetTemperature this is what broke the widget as I assume you are running 3.0.2.
Change the code to reflect this change.
uid: Sensibo_ACcontroller
tags: []
props:
parameters:
- description: The Label at the top of the card
label: Friendly name of your aircon eg. Lounge
required: false
type: TEXT
- description: The index of your items aircon foo_TargetTemperature = foo
label: The index name of your aircon
required: true
type: TEXT
parameterGroups: []
timestamp: Dec 5, 2020, 12:03:56 PM
component: f7-block
style:
--f7-button-text-color: var(--f7-text-color)
--f7-button-bg-color: var(--f7-card-bg-color)
--f7-theme-color-rgb: var(--f7-color-blue-rgb)
class:
- no-padding
slots:
default:
- component: Label
class:
- margin
- no-padding
text: =props.title
style:
text-align: center
height: auto
font-size: 16px
- component: f7-row
class:
- margin
slots:
default:
- component: f7-col
slots:
default:
- component: oh-button
action: toggle
actionItem: =(props.airconditioner + "_MasterSwitch")
actionCommand: ON
actionCommandAlt: OFF
icon-f7: power
iconSize: 28
iconColor: '=(items[props.airconditioner + "_MasterSwitch"].state === "OFF") ? "red" : "green"'
style:
--f7-button-bg-color: transparent
--f7-button-hover-bg-color: transparent
height: auto
font-size: 12px
- component: f7-col
style:
text-align: right
slots:
default:
- component: Label
text: =items[props.airconditioner + "_CurrentTemperature"].state.displayState || items[props.airconditioner + "_CurrentTemperature"].state
style:
white-space: nowrap
text-overflow: elipsis
heigh: auto
font-size: 12px
- component: Label
text: =items[props.airconditioner + "_CurrentHumidity"].displayState || items[props.airconditioner + "_CurrentHumidity"].state
style:
white-space: nowrap
heigh: auto
font-size: 12px
- component: f7-row
class:
- justify-content-center
slots:
default:
- component: oh-knob
min: 18
max: 30
stepSize: 1
item: =[props.airconditioner + '_TargetTemperature']
- component: f7-row
class:
- margin
slots:
default:
- component: f7-col
slots:
default:
class:
- margin
- display-flex
- flex-direction-column
action: command
actionItem: =(props.airconditioner + '_Mode')
actionCommand: ="auto"
icon-f7: arrow_2_circlepath
iconColor: '=(items[props.airconditioner + "_Mode"].state === "auto") ? "red" : "gray"'
text: AUTO
textColor: '=(items[props.airconditioner + "_Mode"].state === "auto") ? "red" : "gray"'
style:
--f7-button-pressed-bg-color: transparent
font-size: 8px
height: auto
- component: f7-col
slots:
default:
class:
- margin
- display-flex
action: command
actionCommand: ="heat"
icon-f7: thermometer_sun
iconColor: '=(items[props.airconditioner + "_Mode"].state === "heat") ? "orange" : "gray"'
text: HEAT
textColor: '=(items[props.airconditioner + "_Mode"].state === "heat") ? "black" : "gray"'
style:
font-size: 8px
height: auto
- component: f7-col
slots:
default:
class:
- margin
- display-flex
action: command
actionCommand: ="dry"
icon-f7: drop
iconColor: '=(items[props.airconditioner + "_Mode"].state === "dry") ? "yellow" : "gray"'
text: DRY
textColor: '=(items[props.airconditioner + "_Mode"].state === "dry") ? "black" : "gray"'
style:
font-size: 8px
height: auto
- component: f7-col
slots:
default:
class:
- margin
- display-flex
action: command
actionCommand: ="fan"
icon-f7: wind
iconColor: '=(items[props.airconditioner + "_Mode"].state === "fan") ? "white" : "gray"'
text: FAN
textColor: '=(items[props.airconditioner + "_Mode"].state === "fan") ? "black" : "gray"'
style:
font-size: 8px
height: auto
- component: f7-col
slots:
default:
class:
- margin
- display-flex
action: command
actionCommand: ="cpp;"
icon-f7: thermometer_snowflake
iconColor: '=(items[props.airconditioner + "_Mode"].state === "cool") ? "blue" : "gray"'
text: COOL
textColor: '=(items[props.airconditioner + "_Mode"].state === "cool") ? "blue" : "gray"'
style:
font-size: 8px
height: auto
- component: f7-row
config: {}
slots:
default:
- component: f7-col
slots:
default:
action: options
actionItem: =(props.airconditioner + '_FanLevel')
class:
- margin
- display-flex
icon-f7: chart_bar
iconColor: yellow
text: =items[props.airconditioner + '_FanLevel'].state
style:
font-size: 12px
height: auto
- component: f7-col
slots:
default:
action: options
actionItem: =(props.airconditioner + '_SwingMode')
class:
- margin
- display-flex
icon-f7: arrow_up_down_circle
iconColor: green
text: =items[props.airconditioner + '_SwingMode'].state
style:
font-size: 12px
height: auto
Thank you, it works smoothly
Hi there, I’m progressing to HABPanel and page setup. I’ve successfully added your widget to my openHAB developed widgets (thank you, it’s pretty cool) but have a noob question, sorry.
How is this widget added to HABPanel?
Sorry I don’t use HABPanel and the widgets are not compatible
Hi, is this for the V1 Pods, or V2 sky? I’ve got 3 old V1 Pods laying around which I love to get working again.
denominator
(James Bowler)
January 21, 2022, 10:21pm
23
I think they interface with the api the same.
They do use the same API key, but the binding requires a MAC, which the old V1 pods don’t have. The newer pods use Wifi, while the V1 pods use a hub through which they connect to the internet. I’ve managed to get the pod’s identities, but cannot add them to the binding because of the lack of forementioned MAC.
Is there a way to modify the binding so that the old V1’s can be reused? I imagine there’s a lot of them just laying around doing nothing
I’m not a developer but have good technical IT knowledge and am more than willing in participating making this work!
seime
(Arne S)
January 25, 2022, 10:46am
25
To be honest, it wont be on top of my TODO-list, but someone can create a PR I can certainly find some time to contribute to a review.
There is a feature request for support for Sensibo Air, and I think that will take priority over the old devices
Thanks, but what is a PR??
seime
(Arne S)
February 1, 2022, 6:49am
27
PR = Pull request. Someone makes necessary changes to the code, and binding owner and someone from the OpenHab team do code review.
I found a Sensibo API Integration - Based on Rules Sensibo API Integration - Based on Rules
According to its maker it works on the v1 Pods, but is for OH2. Wouldnt that be a good startingpoint?
I bumped that 2 years old discussion, maybe it’ll lead to a working solution
denominator
(James Bowler)
February 3, 2022, 10:26am
29
You will see that I did post in that tread and had mine working with rules for a long time. OH2 and 3 rule engine is the same so you can try and get them working. You may run into permission issue when running command line operations. Most people don’t have the hardware to be able to test to make sure their code is correct. I know you are a beginner however you need to start somewhere and getting it running in the rules would be a good start.
You could also try your luck on
https://app.bountysource.com/teams/openhab
Thanks, will give it a go and report my succes here
