Hi there!
I was unable to enable or disable the bypass of zones in a PowermaxPro. I could check the status but I couldn’t change it from a sitemap, by sending a command to the item.
I found the issue. The Bypass
feature must be set to manual bypass
(parameters may differ depending on the language used) in order to be able to enable or disable by using commands on the item.
Best.
