Separating automated switching from user input
I have an Homematic light switch. Light is switched on either by user or by a rule. If light is switched on by a rule there are several other parameters that are configured as well.
How do you separate user switching from rule-based switching?
At the moment I just have an additional global variable set (and unset via timer), if a rule based switching occurs.
However, is there an easier way?
Daniel
Here are some different ways to do it.
