i need to test a fix for REGEX parameter of serial binding (In OH1 or OH2).
It is necessary to check if the following fix won’t break any existing Serial binding with REGEX that you have.
Jar to test can be found here
Download it to your addons folder and restart OH and you are good to go.
To remove just remove the jar from addons folder and restart again
