I’m just getting started with openhab and things are going ok – so far so good.
I have a xantech mrc88 that’s connected to an globalcache ip2sl (http://www.globalcache.com/products/itach/ip2slspecs/)
Where do I get started on creating a binding(?) to the xantech? Do I look at the globalcache code and go through that? Do I start a new “xantech” binding? Do I use TCP to write commands through the ip2sl’s serial port and read from the serial port?
Thanks!
