I moved from my old Raspberry 3 to an new Raspberry 4 and so i used Openhabian with OpenHab3.
So far i really like the new version and everthin works as before or even better.
But i have one thing that won’t work: RaZberry and the Serial configuration
When i use openhabian-config and choose both options
(RPi) Disable serial console
(RPi3/4) move Bluetooth to mini UART
then after a reboot openhab keeps restarting but in the short period it is running i can see that /dev/ttyAMA0 is useable and recognized in Openhab.
When i just choose
and reboot, OpenHab runs stable again but no /dev/ttyAMA0 is useable.
Does anyone of you have the same problem? Or do you see what i’m doing wrong?
ec 23 22:25:49 OpenHabPi frontail[368]: tail: auf ‘/var/log/openhab/openhab.log’ kann nicht mehr zugegriffen werden
Dec 23 22:25:49 OpenHabPi frontail[368]: : Datei oder Verzeichnis nicht gefunden
Dec 23 22:25:49 OpenHabPi frontail[368]: tail: ‘/var/log/openhab/openhab.log’ ist aufgetaucht; folge der neuen Datei
Dec 23 22:25:50 OpenHabPi frontail[368]: tail: auf ‘/var/log/openhab/events.log’ kann nicht mehr zugegriffen werden: Datei oder Verzeichnis nicht gefunden
Dec 23 22:25:50 OpenHabPi frontail[368]: tail: ‘/var/log/openhab/events.log’ ist aufgetaucht; folge der neuen Datei
that is the content of the openhab.log and events.log file. I was more refering to the linux /var/log/syslog file as this contains logs from the complete system.
