When defining Items via PaperUI you can set Category. This defines what icon is being used.
Is it possible to do the same when defining items via text-files?
as I understand it, the “category” in PaperUI indicates the icon used in your sitemap.
In a text based config file, you would put this into like this:
Number Aussentemperatur
"Außentemperatur [%.1f °C]"
<temperature>
(gTemperaturen, gAussen)
[ "CurrentTemperature" ]
{ channel="homematic:HM-WDS10-TH-O:ccu2:MEQxxx:1#TEMPERATURE" }
In this example, will be the icon used. Hope that helps
Cheers,
Marianne
Oh yes of course, you set that by <icon>
Hmm, time to go to bed
