Set item DateTimeType minus mintues
datetimetype
Tags: #<Tag:0x00007f014b79c8d8>
(Ahiel) #1
How can I set item data as DateTimeType - 10 minutes?
I’m using now the item.postUpdate(new DateTimeType) but I need to set the time -10 mintues (I’m using it to know when I’m living home - no ping for 10 minutes, I want to update the item to -10 minutes)
Thanks?
(Sascha Billian) #2
MyItem.postUpdate(now.minusMinutes(10))
(Ahiel) #3
But it is not DateTimeType and it is not recommended to use it as far as I remember, am I wrong?
(Sascha Billian) #4
Oh, sorry. I didn’t note that the types are differen. The following article shows some possibilities to convert Joda DateTime to DateTimeType. Maybe it helps:
(Ahiel) #5
Thank look like it is not updated.
The constructor DateTimeType(Calendar) is deprecated
(Vincent Regaud) #6
@Ahiel
(Ahiel) #7
So the right way to do it is:
Or
MyItem.postUpdate(now.minusMinutes(10).toString)
(Vincent Regaud) #8
First one
(Ahiel) #9
I’m getting:
[ERROR] [.model.rule.runtime.internal.engine.RuleEngineImpl] - Error during the execution of startup rule ‘Initialize variables’: Could not invoke method: org.eclipse.smarthome.model.script.actions.BusEvent.postUpdate(org.eclipse.smarthome.core.items.Item,org.eclipse.smarthome.core.types.State) on instance: null
(Vincent Regaud) #10
How did you create you item?
(Ahiel) #11
DateTime MyItem “leave home at [%1$tm/%1$td %1$tH:%1$tM]”
