Setup: RPi4 4GB RAM with Openhabian fresh installed 3 days ago, Main Channel (3.2.0)
Max Cube Gateway
I found a weired behavior, I set up the Sitemaps and want to add a Setpoint (or Slider).
But when I add a label, I can not adjust the Setpoint (or Slider) any more and get a error in fronttail sometimes.
The order of the properties for a sitemap element is fixed. You can’t mix up the order. The label goes before the min, max, and step properties. See Sitemaps | openHAB.
Since it works in the Android app the best I can offer is for you to open an issue on BasicUI in the webuis repo as that app appears to have a bug. How to file an Issue
okay, thank you for the fast help,
I found even more weired behavior, for example if I have the Item double in the Frame (1x with label one 1x without) and use the Setpoint without label first then the Setpoint with label works too until I refresh the Page.
I will collect more information and try to open a issue.
