Hi
I have an issue with the setpoint in sitemaps. The iOS app always sets the values with 1 decimal although the definition of the item is a number without decimals and the step definition in the sitemap is set to 1.
items:
Number doorAlertNightStart "Nachtalarm Start [%d:00]" <clock> (gPersist,Garadget)
Number doorAlertNightEnd "Nachtalarm Ende [%d:00]" <clock> (gPersist,Garadget)
Number doorAlertDurationValue "Dauer Status offen [%d Min]" <clock> (gPersist,Garadget)
sitemap:
Setpoint item=doorAlertDurationValue label="Dauer Status offen" icon="clock" minValue=1 maxValue=60 step=1
Setpoint item=doorAlertNightStart label="Nachtalarm Start" icon="clock" minValue=12 maxValue=23 step=1
Setpoint item=doorAlertNightEnd label="Nachtalarm Ende" icon="clock" minValue=0 maxValue=12 step=1
The iOS app shows for the setpoints 1 digit after the decimal point:
The same sitemap in Safari (on iOS device) and in any webbrowser shows it correctly without decimals:
Also in the events.log, the decimals are there when the value is changed with the iOS app but not when the value is changed in a browser.
changed in IOS app:
2017-08-31 21:12:51.958 [ome.event.ItemCommandEvent] - Item 'doorAlertNightEnd' received command 7.0
2017-08-31 21:12:51.960 [vent.ItemStateChangedEvent] - doorAlertNightEnd changed from 6 to 7.0
2017-08-31 21:12:54.356 [ome.event.ItemCommandEvent] - Item 'doorAlertNightEnd' received command 6.0
2017-08-31 21:12:54.358 [vent.ItemStateChangedEvent] - doorAlertNightEnd changed from 7.0 to 6.0
changed in browser:
2017-08-31 21:21:05.961 [ome.event.ItemCommandEvent] - Item 'doorAlertNightEnd' received command 7
2017-08-31 21:21:05.962 [vent.ItemStateChangedEvent] - doorAlertNightEnd changed from 6.0 to 7
2017-08-31 21:21:07.895 [ome.event.ItemCommandEvent] - Item 'doorAlertNightEnd' received command 6
2017-08-31 21:21:07.895 [vent.ItemStateChangedEvent] - doorAlertNightEnd changed from 7 to 6
Is there a bug in the iOS app or do I have a bug in my setup?
regards
Remo
