Hi.
I’m controlling my room temperature with one Danfoss thermostat (014G0160) and on my three water radiators I have the Fibaro FGT-001 Thermostatic Valve. I control them via rules that set the setpoint according to the time of day - colder at night and on work hours and warmer when I’m home and awake.
rule "Work Morning 23.0" when Time cron "0 30 4 ? * MON-FRI *" then DanfossSetpoint.sendCommand(24.0) end
And I keep the temperature stable with this rule:
rule "Elutoa radikate lylitamine"
Item DanfossSetpoint changed or
Item DanfossTemperature changed
var Number cur_temp = DanfossTemperature.state as Number
var Number setpoint = DanfossSetpoint.state as Number
val Number hysteresis = 0.2
if (cur_temp < (setpoint - hysteresis)) {
if (Thermostat1_ThermostatMode.state !=1) {Thermostat1_ThermostatMode.sendCommand(1)}
(Thermostat2_Mode.state != 1) {Thermostat2_Mode.sendCommand(1)}
(KitchenThermostatMode.state != 1) {KitchenThermostatMode.sendCommand(1)}
else if(cur_temp > setpoint - hysteresis) {
if (Thermostat1_ThermostatMode.state != 0) {Thermostat1_ThermostatMode.sendCommand(0)}
(Thermostat2_Mode.state != 0) {Thermostat2_Mode.sendCommand(0)}
(KitchenThermostatMode.state != 0) {KitchenThermostatMode.sendCommand(0)}
This works perfectly. But when I set the temperature(setpoint) manually from the Dnafoss thermostat, it sets it for just a second and reverts it right away. Then when I check the setpoint on the thermostat,it still shows the one I set but when checking the Openhab conrol page, it shows the reverted setpoint.
Any ideas what’s going on?
Also, as you can see in the log, is that the change command is sent every time when thermostat temperature changes even 0.1 degrees, but it should be send only when it changes over or under the setpoint. Ideas on that aswell?
Best,
Marko
2020-03-11 08:29:41.721 [vent.ItemStateChangedEvent] - DanfossSetpoint changed from 18 ▒C to 24 ▒C
2020-03-11 08:29:41.744 [ome.event.ItemCommandEvent] - Item 'Thermostat1_ThermostatMode' received command 1
2020-03-11 08:29:41.747 [nt.ItemStatePredictedEvent] - Thermostat1_ThermostatMode predicted to become 1
2020-03-11 08:29:41.763 [ome.event.ItemCommandEvent] - Item 'Thermostat2_Mode' received command 1
2020-03-11 08:29:41.766 [vent.ItemStateChangedEvent] - Thermostat1_ThermostatMode changed from 0 to 1
2020-03-11 08:29:41.773 [nt.ItemStatePredictedEvent] - Thermostat2_Mode predicted to become 1
2020-03-11 08:29:41.779 [ome.event.ItemCommandEvent] - Item 'KitchenThermostatMode' received command 1
2020-03-11 08:29:41.784 [vent.ItemStateChangedEvent] - Thermostat2_Mode changed from 0 to 1
2020-03-11 08:29:41.788 [nt.ItemStatePredictedEvent] - KitchenThermostatMode predicted to become 1
2020-03-11 08:29:41.792 [vent.ItemStateChangedEvent] - KitchenThermostatMode changed from 0 to 1
2020-03-11 08:29:43.880 [vent.ItemStateChangedEvent] - DanfossSetpoint changed from 24 ▒C to 18 ▒C
2020-03-11 08:29:43.928 [ome.event.ItemCommandEvent] - Item 'Thermostat1_ThermostatMode' received command 0
2020-03-11 08:29:43.932 [ome.event.ItemCommandEvent] - Item 'Thermostat2_Mode' received command 0
2020-03-11 08:29:43.941 [ome.event.ItemCommandEvent] - Item 'KitchenThermostatMode' received command 0
2020-03-11 08:29:43.950 [nt.ItemStatePredictedEvent] - Thermostat1_ThermostatMode predicted to become 0
2020-03-11 08:29:43.954 [nt.ItemStatePredictedEvent] - Thermostat2_Mode predicted to become 0
2020-03-11 08:29:43.960 [nt.ItemStatePredictedEvent] - KitchenThermostatMode predicted to become 0
2020-03-11 08:29:43.965 [vent.ItemStateChangedEvent] - Thermostat1_ThermostatMode changed from 1 to 0
2020-03-11 08:29:43.968 [vent.ItemStateChangedEvent] - Thermostat2_Mode changed from 1 to 0
2020-03-11 08:29:43.971 [vent.ItemStateChangedEvent] - KitchenThermostatMode changed from 1 to 0
2020-03-11 08:29:44.458 [vent.ItemStateChangedEvent] - Thermostat2_Mode changed from 0 to 1
2020-03-11 08:29:45.315 [vent.ItemStateChangedEvent] - KitchenThermostatMode changed from 0 to 1
2020-03-11 08:29:52.203 [vent.ItemStateChangedEvent] - Thermostat2_Mode changed from 1 to 0
2020-03-11 08:29:54.291 [vent.ItemStateChangedEvent] - KitchenThermostatMode changed from 1 to 0
2020-03-11 08:31:17.209 [vent.ItemStateChangedEvent] - DanfossTemperature changed from 22.76 ▒C to 22.64 ▒C
2020-03-11 08:31:17.241 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:6675270d:node11' has been updated.
2020-03-11 08:31:17.264 [ome.event.ItemCommandEvent] - Item 'Thermostat2_Mode' received command 0
2020-03-11 08:31:17.272 [nt.ItemStatePredictedEvent] - Thermostat2_Mode predicted to become 0
2020-03-11 08:31:17.287 [ome.event.ItemCommandEvent] - Item 'KitchenThermostatMode' received command 0
2020-03-11 08:31:17.294 [nt.ItemStatePredictedEvent] - KitchenThermostatMode predicted to become 0
