this is my first post, trying to use in the sitemap the setpoint mode of the netatmo module my configuration is the follow:
Setpoint item=Termostato_Setpoint label="Riscaldamento [%.0f ºC]" icon="heating" minValue=18 maxValue=24 step=1.0
The setpoint is working, but I see not the setted temperature.
Why?
hr3
(Harry)
2
Post your item-definition please and screenshots form the netatmo-configuration.
Items are defined inside the paper-UI (see screenshot) in the /etc/openhab2/items/ I have only a group and voice command.
my sitemap is:
sitemap casa label="Casa" {
Frame {
Text label="Soggiorno" icon="parents_2_4" {
Default item=LuceDivano_Switch label="Soggiorno"
Default item=Flaminia_Temperature label="Temperatura" valuecolor=[<18="blue",<25="orange",>27="red"]
Default item=Flaminia_Humidity label="Umidità" valuecolor=[<20.1="green",<29.1="blue",<28.1="yellow",<45.1="orange",<54.1="red",>54.1="maroon"]
Default item=Flaminia_CO2 label="Co2" icon="carbondioxide" valuecolor=[<800="green",<1000="orange",<1400="red",>1399="maroon"]
Default item=Flaminia_Pressure
Default item=Flaminia_Noise label="Rumorosità" icon="noise" valuecolor=[<42="green",<50="orange",>60="red"]
Switch item=Condizionatore_Pressbutton label="Condizionatore" icon="snow" mappings=["Spegni"="Spegni","Estivo 20°"="Freddo","Invernale 31°"="Caldo"]
Text label="Terrazzo" icon="terrace" {
Default item=Terrazzo label="Luci interne"
Default item=LuciTerrazzo_Switch2 label="Luci esterne"
Default item=Terrazzo_Temperature label="Temperatura" valuecolor=[<18="blue",<25="orange",>27="red"]
Default item=Terrazzo_Humidity label="Umidità" valuecolor=[<20.1="green",<29.1="blue",<28.1="yellow",<45.1="orange",<54.1="red",>54.1="maroon"]
Default item=Pluviometro_Rain label="Pioggia"
Default item=Anemometro_WindStrength label="Vento"
Default item=Anemometro_GustStrength label="Raffiche"
Text label="Persiane" icon="rollershutter" {
Default item=Terrace_Shutter label="Terrazza"
Default item=SerrandaCameraDaLetto_BlindsControl label="Camera [%.0f]"
Default item=SerrandaCameretta_BlindsControl label="Studio [%.0f]"
Default item=SerrandaBagno_BlindsControl label="Bagno [%.0f]"
Default item=SerrandaCucina_BlindsControl label="Cucina [%.0f]"
Switch item=gShutter label="Tutte" mappings=[UP="SU", STOP="X", DOWN="GIU"]
Text label="Volume" icon="soundvolume" {
Default item=RXV781Main_Zone_Zone_channels_Power label="Power"
Default item=RXV781Main_Zone_Zone_channels_Volume label="Volume"
Default item=RXV781Main_Zone_Zone_channels_Mute label="Muto"
Can you try to reproduce this issue with the latest beta? https://play.google.com/store/apps/details?id=org.openhab.habdroid.beta
Does it work in Basic UI?
I use paper-ui (I didn’t installed basic) in the paper-ui I don’t see the set value same as the android app
Can you install basic UI and test it there?
