- Platform information:
- Hardware: R Pi 3 Model B
- OS: openhabian 1.4.1
I did a clean installation of openhabian 1.4.1.
After the first boot I want to set my locale to connect with the local wifi adapter of the pi to the network.
But setting the locale fails every time. Maybe you have an idea what I am doing wrong?
Thank you in advance, BR Sebastian
[16:29:17] openhabian@openHABianPi:~$ sudo openhabian-config
[sudo] Passwort für openhabian:
Das hat nicht funktioniert, bitte nochmal probieren.
2018-05-20_16:29:38_CEST [openHABian] Checking for root privileges... OK
2018-05-20_16:29:38_CEST [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2018-05-20_16:29:40_CEST [openHABian] openHABian configuration tool version: [master]v1.4.1-399(
47771f8)
2018-05-20_16:29:40_CEST [openHABian] Checking for changes in origin... OK
2018-05-20_16:29:49_CEST [openHABian] Setting locale based on user choice...
Generating locales (this might take a while)...
de_CH.UTF-8... done
Generation complete.
*** update-locale: Error: invalid locale settings: LC_CTYPE=de_DE.UTF-8 LC_ALL=de_DE.UTF-8 LANG
UAGE=de_DE.UTF-8 LANG=de_CH.UTF-8
$ update-locale LANG=#de_DE.UTF-8 LC_ALL=#de_DE.UTF-8 LC_CTYPE=#de_DE.UTF-8 LANGUAGE=#de_DE.UTF-
8
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = "de_DE.UTF-8",
LC_ALL = "de_DE.UTF-8",
LC_CTYPE = "de_DE.UTF-8",
LANG = "de_DE.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
*** update-locale: Error: invalid locale settings: LANGUAGE=#de_DE.UTF-8 LANG=#de_DE.UTF-8 LC_C
TYPE=#de_DE.UTF-8 LC_ALL=#de_DE.UTF-8
2018-05-20_16:30:21_CEST [openHABian] Checking for default openHABian username:password combinat
ion... perl: warning: Setting locale failed.
FAILED
