Hi - Any help appreciated
This is the way the item is set up in the items file:
Switch saloon_light “Saloon Light” (Saloon) { serial="/dev/ttyAMA0@9600,REGEX(mainlight,([^:]+))" }
I get this error:
2017-03-22 08:38:04.532 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type ‘serial’ of item ‘saloon_light’ could not be parsed correctly.
java.lang.NullPointerException
And this is the string I’m sending from an arduino:
Serial.println(“mainlight,on:downlight,on:headslight,on:galleylight,on:bedlight,on:nightlight,on:cockpitlight,on:frontlight,on:voltage,12.4:charge,10:amps,5:webasto,5:radiator,5:engine,on:temp,80:oil,10:diesel,90:water,100:”);
