Made a look trough the README.
Looks much better.
I made some comments on your pull request.
I tried the following:
- deleting everything that contains to withings binding.
- A systemwide filemane search with * withings * endet up with no results
- A search for files containing * withings * ended up with this:
Thats clear so far, because I changed the logleve for this binding. I Think this has no effect on my problemSearch "withings" (12 hits in 2 files) \\OPENHAB2\openHAB-share\openhab2-userdata\etc\org.ops4j.pax.logging.cfg (6 hits) Line 115: log4j2.logger.withings.level = TRACE Line 116: log4j2.logger.withings.name = withings Line 116: log4j2.logger.withings.name = withings Line 117: log4j2.logger.org_openhab_binding_withings.level = TRACE Line 118: log4j2.logger.org_openhab_binding_withings.name = org.openhab.binding.withings Line 118: log4j2.logger.org_openhab_binding_withings.name = org.openhab.binding.withings \\OPENHAB2\openHAB-share\openhab2-userdata\config\org\ops4j\pax\logging.config (6 hits) Line 60: log4j2.logger.org_openhab_binding_withings.level="TRACE" Line 61: log4j2.logger.org_openhab_binding_withings.name="org.openhab.binding.withings" Line 61: log4j2.logger.org_openhab_binding_withings.name="org.openhab.binding.withings" Line 82: log4j2.logger.withings.level="TRACE" Line 83: log4j2.logger.withings.name="withings" Line 83: log4j2.logger.withings.name="withings"
- Now I threw the file
org.openhab.binding.withings-1.10.0.jar
to theaddons
folder endig up with this log:15:53:25.744 [DEBUG] [org.openhab.binding.withings ] - BundleEvent INSTALLED - org.openhab.binding.withings 15:53:26.332 [DEBUG] [org.openhab.binding.withings ] - BundleEvent RESOLVED - org.openhab.binding.withings 15:53:27.049 [DEBUG] [org.openhab.binding.withings ] - BundleEvent UNRESOLVED - org.openhab.binding.withings 15:53:27.507 [DEBUG] [org.openhab.binding.withings ] - BundleEvent RESOLVED - org.openhab.binding.withings 15:53:27.843 [DEBUG] [org.openhab.binding.withings ] - BundleEvent STARTING - org.openhab.binding.withings 15:53:28.297 [DEBUG] [org.openhab.binding.withings ] - BundleEvent STARTED - org.openhab.binding.withings 15:53:28.718 [DEBUG] [org.openhab.binding.withings ] - ServiceEvent REGISTERED - {org.osgi.service.cm.ManagedService}={service.pid=org.openhab.withings-oauth, osgi.command.function=[startAuthentication,finishAuthentication], component.name=org.openhab.binding.withings.authenticator, component.id=333, osgi.command.scope=withings, service.id=1235, service.bundleid=219, service.scope=bundle} - org.openhab.binding.withings 15:53:30.402 [ERROR] [org.apache.felix.configadmin ] - [org.osgi.service.cm.ManagedService, id=1235, bundle=219/file:/usr/share/openhab2/addons/org.openhab.binding.withings-1.10.0.jar]: Updating property consumerKey of configuration org.openhab.withings-oauth caused a problem: The given configuration key is unknown! org.osgi.service.cm.ConfigurationException: consumerKey : The given configuration key is unknown! at org.openhab.binding.withings.internal.api.WithingsAuthenticator.updated(WithingsAuthenticator.java:251) [219:org.openhab.binding.withings:1.10.0] at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189) [7:org.apache.felix.configadmin:1.8.14] at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152) [7:org.apache.felix.configadmin:1.8.14] at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85) [7:org.apache.felix.configadmin:1.8.14] at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.provide(ConfigurationManager.java:1463) [7:org.apache.felix.configadmin:1.8.14] at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.run(ConfigurationManager.java:1419) [7:org.apache.felix.configadmin:1.8.14] at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:141) [7:org.apache.felix.configadmin:1.8.14] at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:109) [7:org.apache.felix.configadmin:1.8.14] at java.lang.Thread.run(Thread.java:745) [?:?] 15:53:30.404 [DEBUG] [org.openhab.binding.withings ] - ServiceEvent REGISTERED - {org.openhab.model.item.binding.BindingConfigReader, org.openhab.binding.withings.WithingsBindingProvider}={component.name=org.openhab.binding.withings.genericbindingprovider, component.id=335, service.id=1236, service.bundleid=219, service.scope=bundle} - org.openhab.binding.withings 15:53:34.954 [DEBUG] [org.openhab.binding.withings ] - ServiceEvent REGISTERED - {org.osgi.service.cm.ManagedService}={service.pid=org.openhab.withings, component.name=org.openhab.binding.withings.binding, component.id=334, service.id=1238, service.bundleid=219, service.scope=bundle} - org.openhab.binding.withings
I really don’t know what I am doing wrong or waht else I could do.
Do I need a withings.cfg before I drop the *jar-FIle into the addons folder?
If so, what has to be in there? I can’t find any details about it in the README
EDIT:
For clarification:
I saw that there are some mandatory parameters:
- consumerkey
- consumersecret
- redirectUrl
The README just says "Your …"
Maybe I am a noob but I dont know what to fill in there and whats the correct typograpy.
Thanks alot for your help.
