Setting up Xiaomi Mi SmartPlug (Zigbee) with OpenHAB 3
You can simplify this a bit. You can get rid of your two JS transformations in your Switch Channels by simply adding
on="1",
off="0"
to your Switch Channel configuration where relevant, and
on="true",
off="false"
where relevant. Just remember to remove the JS transformation, but add in a JSONPATH transformation if required.
You can double check the available options for each Channel Type in the documentation.
