Hi
I would like to ask about an issue i’m having with openhabian and not with raspbian Stretch.
well by following this guide
i could setup my wifi without a problem but in openhabian i got an issue when i try to restart the dhcpd using this command:
sudo service dhcpcd restart
What issue? Please be a bit more specific
Openhabian uses the newer ‘systemd’ based init, so the service
command is depricated and replaced by systemctl
. Please try:
sudo systemctl restart dphcp
Note that the command (restart) and the service name (dhcpd) are swapped.
still gettinh the same error
Warning: dhcpcd.service changed on disk. Run ‘systemctl daemon-reload’ to reload units.
Job for dhcpcd.service failed because the control process exited with error code.
See “systemctl status dhcpcd.service” and “journalctl -xe” for details.
i figured it out thanks everybody
Please post how you figured it out so future readers who have the same problem know what to do.
Well it depends, cause ppl were having the same error but for different reasons so i had to read the journal with this command
journalctl -xe
and it was saying that it didnt find any interface to start the dhcp on its a little bit missleading as an error cause the main reason is that we disabled the wpa.supplicant but the wlan0 was still on autohotplug
so i had to clear the /etc/network/interface file from any interface then stop the 2 services hostapd and dnsmasq to avoid any future confusion and restart the dhcp so it worked like a charm.
