Logs from first pressing Eltako FT4 upper-left, lower-left, upper-right, lower-right,
then same sequence for the Jung ENO. - The Jung returns the same channel B, parameter I for all taps.
I am on old OpenHAB 1.8.3 and should probably upgrade to the latest Enocean binding.
pi@haus:/opt/openhab-1.8.3-runtime/logs $ tail -f *.log | grep -i enocean
18:40:40.552 [DEBUG] [.e.internal.bus.EnoceanBinding:285 ] - Received new value Pressed for device at EnoceanParameter: {id="FE:FD:2F:BF", channel="A", parameter="O"}
18:40:40.553 [DEBUG] [.e.internal.bus.EnoceanBinding:329 ] - Packet received: RadioPacketRPS[header=[Header: dataLength=00, optionalDataLength=07, packetType=01, crc8h=6C], payload=Payload: data=[], optionaldata=[01, FF, FF, FF, FF, 46, 00], crc8d=-106], raw=[55, 00, 00, 07, 01, 6C, 01, FF, FF, FF, FF, 46, 00, 96], [sender=FE:FD:2F:BF, repeaterCount=0]
18:40:40.759 [DEBUG] [.e.internal.bus.EnoceanBinding:285 ] - Received new value Released for device at EnoceanParameter: {id="FE:FD:2F:BF", channel="A", parameter="O"}
18:40:40.760 [DEBUG] [.e.internal.bus.EnoceanBinding:329 ] - Packet received: RadioPacketRPS[header=[Header: dataLength=00, optionalDataLength=07, packetType=01, crc8h=6C], payload=Payload: data=[], optionaldata=[01, FF, FF, FF, FF, 41, 00], crc8d=-3], raw=[55, 00, 00, 07, 01, 6C, 01, FF, FF, FF, FF, 41, 00, FD], [sender=FE:FD:2F:BF, repeaterCount=0]
18:40:42.638 [DEBUG] [.e.internal.bus.EnoceanBinding:285 ] - Received new value Pressed for device at EnoceanParameter: {id="FE:FD:2F:BF", channel="B", parameter="I"}
18:40:42.640 [DEBUG] [.e.internal.bus.EnoceanBinding:285 ] - Received new value Pressed for device at EnoceanParameter: {id="FE:FD:2F:BF", channel="A", parameter="I"}
18:40:42.642 [DEBUG] [.e.internal.bus.EnoceanBinding:329 ] - Packet received: RadioPacketRPS[header=[Header: dataLength=00, optionalDataLength=07, packetType=01, crc8h=6C], payload=Payload: data=[], optionaldata=[01, FF, FF, FF, FF, 41, 00], crc8d=-3], raw=[55, 00, 00, 07, 01, 6C, 01, FF, FF, FF, FF, 41, 00, FD], [sender=FE:FD:2F:BF, repeaterCount=0]
18:40:42.848 [DEBUG] [.e.internal.bus.EnoceanBinding:285 ] - Received new value Released for device at EnoceanParameter: {id="FE:FD:2F:BF", channel="B", parameter="I"}
18:40:42.849 [DEBUG] [.e.internal.bus.EnoceanBinding:329 ] - Packet received: RadioPacketRPS[header=[Header: dataLength=00, optionalDataLength=07, packetType=01, crc8h=6C], payload=Payload: data=[], optionaldata=[01, FF, FF, FF, FF, 43, 00], crc8d=-41], raw=[55, 00, 00, 07, 01, 6C, 01, FF, FF, FF, FF, 43, 00, D7], [sender=FE:FD:2F:BF, repeaterCount=0]
18:40:43.954 [DEBUG] [.e.internal.bus.EnoceanBinding:285 ] - Received new value Pressed for device at EnoceanParameter: {id="FE:FD:2F:BF", channel="B", parameter="O"}
18:40:43.955 [DEBUG] [.e.internal.bus.EnoceanBinding:329 ] - Packet received: RadioPacketRPS[header=[Header: dataLength=00, optionalDataLength=07, packetType=01, crc8h=6C], payload=Payload: data=[], optionaldata=[01, FF, FF, FF, FF, 4A, 00], crc8d=106], raw=[55, 00, 00, 07, 01, 6C, 01, FF, FF, FF, FF, 4A, 00, 6A], [sender=FE:FD:2F:BF, repeaterCount=0]
18:40:44.121 [DEBUG] [.e.internal.bus.EnoceanBinding:285 ] - Received new value Released for device at EnoceanParameter: {id="FE:FD:2F:BF", channel="B", parameter="O"}
18:40:44.122 [DEBUG] [.e.internal.bus.EnoceanBinding:329 ] - Packet received: RadioPacketRPS[header=[Header: dataLength=00, optionalDataLength=07, packetType=01, crc8h=6C], payload=Payload: data=[], optionaldata=[01, FF, FF, FF, FF, 4A, 00], crc8d=106], raw=[55, 00, 00, 07, 01, 6C, 01, FF, FF, FF, FF, 4A, 00, 6A], [sender=FE:FD:2F:BF, repeaterCount=0]
18:40:44.715 [DEBUG] [.e.internal.bus.EnoceanBinding:285 ] - Received new value Pressed for device at EnoceanParameter: {id="FE:FD:2F:BF", channel="B", parameter="I"}
18:40:44.718 [DEBUG] [.e.internal.bus.EnoceanBinding:329 ] - Packet received: RadioPacketRPS[header=[Header: dataLength=00, optionalDataLength=07, packetType=01, crc8h=6C], payload=Payload: data=[], optionaldata=[01, FF, FF, FF, FF, 46, 00], crc8d=-106], raw=[55, 00, 00, 07, 01, 6C, 01, FF, FF, FF, FF, 46, 00, 96], [sender=FE:FD:2F:BF, repeaterCount=0]
18:40:44.877 [DEBUG] [.e.internal.bus.EnoceanBinding:285 ] - Received new value Released for device at EnoceanParameter: {id="FE:FD:2F:BF", channel="B", parameter="I"}
18:40:44.880 [DEBUG] [.e.internal.bus.EnoceanBinding:329 ] - Packet received: RadioPacketRPS[header=[Header: dataLength=00, optionalDataLength=07, packetType=01, crc8h=6C], payload=Payload: data=[], optionaldata=[01, FF, FF, FF, FF, 47, 00], crc8d=-125], raw=[55, 00, 00, 07, 01, 6C, 01, FF, FF, FF, FF, 47, 00, 83], [sender=FE:FD:2F:BF, repeaterCount=0]
18:40:49.278 [DEBUG] [.e.internal.bus.EnoceanBinding:329 ] - Packet received: RadioPacketRPS[header=[Header: dataLength=00, optionalDataLength=07, packetType=01, crc8h=6C], payload=Payload: data=[], optionaldata=[01, FF, FF, FF, FF, 46, 00], crc8d=-106], raw=[55, 00, 00, 07, 01, 6C, 01, FF, FF, FF, FF, 46, 00, 96], [sender=00:2F:17:B3, repeaterCount=0]
18:40:49.504 [DEBUG] [.e.internal.bus.EnoceanBinding:285 ] - Received new value Released for device at EnoceanParameter: {id="00:2F:17:B3", channel="B", parameter="I"}
18:40:49.507 [DEBUG] [.e.internal.bus.EnoceanBinding:329 ] - Packet received: RadioPacketRPS[header=[Header: dataLength=00, optionalDataLength=07, packetType=01, crc8h=6C], payload=Payload: data=[], optionaldata=[01, FF, FF, FF, FF, 47, 00], crc8d=-125], raw=[55, 00, 00, 07, 01, 6C, 01, FF, FF, FF, FF, 47, 00, 83], [sender=00:2F:17:B3, repeaterCount=0]
18:40:53.501 [DEBUG] [.e.internal.bus.EnoceanBinding:329 ] - Packet received: RadioPacketRPS[header=[Header: dataLength=00, optionalDataLength=07, packetType=01, crc8h=6C], payload=Payload: data=[], optionaldata=[01, FF, FF, FF, FF, 4F, 00], crc8d=43], raw=[55, 00, 00, 07, 01, 6C, 01, FF, FF, FF, FF, 4F, 00, 2B], [sender=00:2F:17:B3, repeaterCount=0]
18:40:53.717 [DEBUG] [.e.internal.bus.EnoceanBinding:285 ] - Received new value Released for device at EnoceanParameter: {id="00:2F:17:B3", channel="B", parameter="I"}
18:40:53.720 [DEBUG] [.e.internal.bus.EnoceanBinding:329 ] - Packet received: RadioPacketRPS[header=[Header: dataLength=00, optionalDataLength=07, packetType=01, crc8h=6C], payload=Payload: data=[], optionaldata=[01, FF, FF, FF, FF, 4D, 00], crc8d=1], raw=[55, 00, 00, 07, 01, 6C, 01, FF, FF, FF, FF, 4D, 00, 01], [sender=00:2F:17:B3, repeaterCount=0]
18:40:56.365 [DEBUG] [.e.internal.bus.EnoceanBinding:329 ] - Packet received: RadioPacketRPS[header=[Header: dataLength=00, optionalDataLength=07, packetType=01, crc8h=6C], payload=Payload: data=[], optionaldata=[01, FF, FF, FF, FF, 44, 00], crc8d=-68], raw=[55, 00, 00, 07, 01, 6C, 01, FF, FF, FF, FF, 44, 00, BC], [sender=00:2F:17:B3, repeaterCount=0]
18:40:56.592 [DEBUG] [.e.internal.bus.EnoceanBinding:285 ] - Received new value Released for device at EnoceanParameter: {id="00:2F:17:B3", channel="B", parameter="I"}
18:40:56.596 [DEBUG] [.e.internal.bus.EnoceanBinding:329 ] - Packet received: RadioPacketRPS[header=[Header: dataLength=00, optionalDataLength=07, packetType=01, crc8h=6C], payload=Payload: data=[], optionaldata=[01, FF, FF, FF, FF, 47, 00], crc8d=-125], raw=[55, 00, 00, 07, 01, 6C, 01, FF, FF, FF, FF, 47, 00, 83], [sender=00:2F:17:B3, repeaterCount=0]
18:40:57.650 [DEBUG] [.e.internal.bus.EnoceanBinding:329 ] - Packet received: RadioPacketRPS[header=[Header: dataLength=00, optionalDataLength=07, packetType=01, crc8h=6C], payload=Payload: data=[], optionaldata=[01, FF, FF, FF, FF, 4F, 00], crc8d=43], raw=[55, 00, 00, 07, 01, 6C, 01, FF, FF, FF, FF, 4F, 00, 2B], [sender=00:2F:17:B3, repeaterCount=0]
18:40:57.907 [DEBUG] [.e.internal.bus.EnoceanBinding:285 ] - Received new value Released for device at EnoceanParameter: {id="00:2F:17:B3", channel="B", parameter="I"}
18:40:57.911 [DEBUG] [.e.internal.bus.EnoceanBinding:329 ] - Packet received: RadioPacketRPS[header=[Header: dataLength=00, optionalDataLength=07, packetType=01, crc8h=6C], payload=Payload: data=[], optionaldata=[01, FF, FF, FF, FF, 4C, 00], crc8d=20], raw=[55, 00, 00, 07, 01, 6C, 01, FF, FF, FF, FF, 4C, 00, 14], [sender=00:2F:17:B3, repeaterCount=0]
^C
