I am following this tutorial to setup openHAB2. After I’ve finished, a lot of bindings are showing errors. The log shows this error at the moment:
!SESSION Wed Oct 07 00:36:15 CEST 2015 -----------------------------------------
!ENTRY org.eclipse.equinox.launcher 4 0 2015-10-07 00:36:15.974
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.ClassNotFoundException: org.eclipse.core.runtime.adaptor.EclipseStarter
at java.net.URLClassLoader.findClass(URLClassLoader.java:381)
at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:666)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
at org.eclipse.equinox.launcher.Main.main(Main.java:1488)
I am using Windows 7, jdk1.8.0_60, maven 3.0.5 and installed openHAB2 with ESH.
Furthermore, I installed openHAB2 with ESH on another machine with ubuntu 14.04 and it is working fine. Only in the openHAB_Runtime.launch
I had to insert javax.jmdns@default:default
, because it was the only thing missing.
EDIT:
Well, this morning I installed the openHAB2 with ESH on a new ubuntu machine and it shows the same amount of errors:
Here I am using ubuntu 14.04 64Bit, oracle java 1.8.0_60, maven 3.0.5. I tried to clean all my projects and run Perform Setup Tasks...
, but still the same errors. I still followed the instructions of this tutorial. Could someone please give me an advice what I should try next? Is there someone with the same problems as me?
