Setup Notification to myopenhab Cloud via NG Rules
Hello all,
has someone an example how I can setup a rule via NG RULE to send a notification to the myopenhab.org cloud on my mobile, when e.g. my rollo is open 100%?
I can only find in NG Rules, values e.g “send a command”, or “Send Text”, but NOT set a notification…
Thanks in advanced.
Scheuerer
Do you mean the UI rule editor? If so, this is currently not implemented. You have some options though…
  1. Use scripted automation rather than the UI rule editor
  2. Use the ‘execute a given script’ Action, which is basically #1 but as a ScriptedAction
Either way, you can use the new rule engine, scripted automation, Jython, and the helper libraries to do something like what is documented here… Actions — openHAB Helper Libraries documentation.
