- Platform information:
- Hardware: Intel X86, 8 GB, 1 TB HDD
Second: Rasperry 32 GB SD - Debian Stetch
- Java Runtime Environment: Oracle 8.2
- openHAB version: 2.3
this is my first post here.
I have a running instance of OH2 that does control mostly KNX and Z-Wave devices. BasicUI working, also remote access through myopenhab.org. 150 items in total.
So far everything perfect.
I intend to set up a smaller second instance for my holiday home. Only Z-Wave plugs and radiator valves. Won‘t be more than 20 devices. The holiday home has a permanent DSL connection.
My iOS app will only work with one myopenhab.org access at a time. Means: setting up the second instance would need to constantly change credentials in the app to connect. Makes no sense.
Further, I understand, I cannot connect from both instances with the same credentials and uploading two different Sitemaps. „main“ from home, „vacation“ from the holiday home.
I would rate myself not-too-rookie with OH2. But in this situation I feel I need to install a different system (Home automatio perhaps) in my holiday home just to avoid switching between credentials in the iOS app. Of course I can have only one instance of the app on my mobile device.
To bring it to the point: I am kind of clueless. I would prefer to go with openHAB, but have no idea how to set this up in my situation.
I appreciate any hint on how to continue. Perhaps you have some advice where to look.
Thank you,
Hanns
- If logs where generated please post these here using code fences:
