After the upgrade from OH3.1 to OH3.2 several Z-Wave devices are no longer reachable. Does anybody have a similar issue or can help with further analysis or problem solving?
Z-Wave entries in the log file:
2022-02-21 18:07:07.882 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2022-02-21 18:07:07.883 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2022-02-21 18:07:14.794 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:serial_zstick:88190bb8’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-02-21 18:07:14.796 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node23’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:14.803 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node22’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:14.810 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node25’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-02-21 18:07:14.812 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node21’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:14.813 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node24’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:14.850 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node25’ changed from ONLINE to ONLINE: Node initialising: PING
2022-02-21 18:07:14.886 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node20’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:14.887 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node29’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:14.889 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node26’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:14.891 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node27’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:14.893 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node28’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:14.919 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node4’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:14.921 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node5’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:14.923 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node3’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:14.926 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node8’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:14.940 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node9’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-02-21 18:07:14.942 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node34’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:14.944 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node33’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:14.951 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node36’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:14.969 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node35’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:14.979 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node30’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:14.981 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node32’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:14.983 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node31’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:14.989 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node38’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:14.991 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node37’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:14.993 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node39’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:14.997 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node45’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:14.999 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node49’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:15.001 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node12’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:15.003 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node11’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:15.007 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node14’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-02-21 18:07:15.009 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node13’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-02-21 18:07:15.012 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node10’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:15.016 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node19’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-02-21 18:07:15.018 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node16’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:15.022 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node15’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:15.024 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node18’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:15.027 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node17’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-02-21 18:07:15.029 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node41’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:15.032 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node40’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:15.034 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node42’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:15.036 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node44’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:15.038 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node50’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:15.040 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node51’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:15.041 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node52’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE: Node not found in Z-Wave network
2022-02-21 18:07:15.107 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node17’ changed from ONLINE to ONLINE: Node initialising: REQUEST_NIF
2022-02-21 18:07:15.196 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node13’ changed from ONLINE to ONLINE: Node initialising: REQUEST_NIF
2022-02-21 18:07:17.149 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node17’ changed from ONLINE: Node initialising: REQUEST_NIF to ONLINE
2022-02-21 18:07:17.390 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node19’ changed from ONLINE to ONLINE: Node initialising: REQUEST_NIF
2022-02-21 18:07:19.379 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node13’ changed from ONLINE: Node initialising: REQUEST_NIF to ONLINE
2022-02-21 18:07:19.762 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node14’ changed from ONLINE to ONLINE: Node initialising: REQUEST_NIF
2022-02-21 18:07:21.295 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node19’ changed from ONLINE: Node initialising: REQUEST_NIF to ONLINE
2022-02-21 18:07:21.714 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node9’ changed from ONLINE to ONLINE: Node initialising: REQUEST_NIF
2022-02-21 18:07:28.670 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node14’ changed from ONLINE: Node initialising: REQUEST_NIF to ONLINE
2022-02-21 18:07:28.963 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node25’ changed from ONLINE: Node initialising: PING to ONLINE: Node initialising: REQUEST_NIF
2022-02-21 18:07:30.007 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node9’ changed from ONLINE: Node initialising: REQUEST_NIF to ONLINE
2022-02-21 18:07:30.619 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘zwave:device:88190bb8:node25’ changed from ONLINE: Node initialising: REQUEST_NIF to ONLINE
Z-Wave network after the upgrade:
Z-Wave stick configuration:
UID: zwave:serial_zstick:88190bb8
label: Z-Wave Serial Controller
thingTypeUID: zwave:serial_zstick
configuration:
controller_softreset: false
security_networkkey: …
security_inclusionmode: 0
controller_suc: false
controller_sisnode: 1
controller_sync: false
controller_master: true
inclusion_mode: 2
port: /dev/ttyACM0
controller_wakeupperiod: 3600
controller_exclude: false
heal_time: 2
controller_inclusiontimeout: 60
controller_hardreset: false
It would be great if anybody could help to solve the issue
