Shelly 2.5 rollershutter and mqtt binding 2.4
  • Platform information:
    • Hardware: _CPUArchitecture/RAM/storage: Raspberry Pi 3
    • OS: _what OS is used and which version: raspbian Linux openhab 4.19.42-v7+ #1219
    • Java Runtime Environment: which java platform is used and what version
      OpenJDK Runtime Environment (Zulu Embedded 8.25.0.76-linux-aarch32hf) (build 1.8.0_152-b76)
      OpenJDK Client VM (Zulu Embedded 8.25.0.76-linux-aarch32hf) (build 25.152-b76, mixed mode, Evaluation)
    • openHAB version: 2.4
I configured via paper UI a shelly2.5 (generic mqtt thingh) device to use as rollershtter. I am using a mosquitto broker and when I send via command line “mosquitto_pub -d -u openhabian --pw xxxxxxxxx -t shellies/shellyswitch25-000208/roller/0/command -m open” the shelly 2.5 works.
I also configured a channel with:
MQTT state topic --> shellies/shellyswitch25-000208/roller/0
MQTT command topic --> shellies/shellyswitch25-000208/roller/0/command
Up value --> open
Down value --> close
Stop value --> stop
I inserted in items file “Rollershutter Shelly1 “SHELLY” {channel=“mqtt:topic:6eefa72f:shelly1”}”
When I use the control panel it does not work.
Is there someone who can help me ?
Regards
RIccardo
There is a known bug in the binding right now with Rollershutter Items. You will need to create a Proxy Rollershutter Item and a Rule that uses the Action to publish the right message for the given command.
Thanks Rich. I am new in Openhab and I don’t understant what can I do. I am able to create a rules but i don’t understand ho to send using openhab the right command. I am able to send MQTT command using mosquitto_pub and the shelly work correctly. Can yiou give me more info ? Thanks
Other question (Sorry :smile:) if i use the MQTT Binding “old” (binding-mqtt1 - 1.13.0) will I have the same problem ?
How to use the MQTT 2 Action is documented in the binding docs (https://www.openhab.org/addons/bindings/mqtt.generic/#rule-actions).
I don’t know if you will have the same problem in MQTT 1.x but I wouldn’t recommend going back to it. The number of users who can help fix problems on this forum is slowing going down. Also, the ability of OH 3 to continue to support OH 1.x version bindings is in doubt.
Thanks. I am reading the docs. What do you mean when you say to create a " Proxy Rollershutter Item" ?
I need to create an item using witch binding ? Thanks for your help and sorry because I disturb you.
BR
i got my shelly’s rollershutters working with following config:
.thing file:
Thing topic Shelly25_xxxxxx "Shelly2.5 Rolluik Achterdeur" @ "Keuken" {
    Channels:
        Type rollershutter : Rolluik    "Rolluik achterdeur"     [ stateTopic="shellies/shellyswitch25-xxxxxx/roller/0/pos", transformationPattern="JS:ShellyRS.js"]
        Type number : Rolluikpos        "Positie achterdeur"     [ commandTopic="shellies/shellyswitch25-xxxxxx/roller/0/command/pos"]
        Type string : Rolluikcmd        "Command achterdeur"     [ commandTopic="shellies/shellyswitch25-xxxxxx/roller/0/command"]
the shellyRS.js file:
(function(i) {
    return (100-i);
}) (input)
this gives the right symbol for the shutter on the sitemap shelly open = 100% vs openHAB open = 0%
.item file:
Rollershutter Rolluik_achterdeur    "Rolluik achterdeur"        <blinds>    { channel="mqtt:topic:mosquitto:Shelly25_xxxxxx:Rolluik", autoupdate="false" }
Number Rolluik_achterdeurpos        "Rolluik achterdeur"                    { channel="mqtt:topic:mosquitto:Shelly25_xxxxxx:Rolluikpos" }
String Rolluik_achterdeurcmd        "Rolluik achterdeur"                    { channel="mqtt:topic:mosquitto:Shelly25_xxxxxx:Rolluikcmd" }
.sitemap:
Default item=Rolluik_achterdeur
and a . rules file:
rule "Shellie2.5 Achterdeur command"
    Item Rolluik_achterdeur received command
    switch (receivedCommand) {
        case UP :
            Rolluik_achterdeurcmd.sendCommand("open")
        case STOP :
            Rolluik_achterdeurcmd.sendCommand("stop")
        case DOWN :
            Rolluik_achterdeurcmd.sendCommand("close")
Hope this helps.
Jan
Hi Jan, i have a question…if I don’t want to use the MQTT protocol but use the http get command is possible to build the same rules to manage a shelly 2.5 linked to a rolleshiutter ?
Thansk for your help .
Ciao
Riccardo
FYI there is a binding on the way :
https://github.com/markus7017/org.openhab.binding.shelly
This is the main thread:
It’s still in beta and uses http calls, the goal is to use Coap in the future.
Maybe it could simplify things.
Thank you! Works perfect!
Hi riccardom, i am not using th shelly 2.5 rollershutters with mqtt. I am using shelly binding that is in the latest 2.5 builds. And it works perfectly. It has already been sugested in this tread by alexxio. Just give it a try.
