- Platform information:
- Hardware: Selly2
- openHAB version: 2.4
Hi there,
could someone help me, as I am really confused. First I had several tries and mismatched MQTT1 and the new from openhab2.4.
I have several shelly 2 in my flat since some weeks but am not able to configure them properly.
The work without problems directly through inserts into my mosquitto but are not proper configured inside openhab.
I have now created a now openhab instance just for testing but am not able to clearly understand everything.
I think that i have configured the broker proper as in Paper UI several devices are in the inbox which follow the homie standard.
My Shelly 2 is configured as a roller shutter for my blinds.
Bridge mqtt:broker:PinkyMqtt [ host="192.168.178.55", secure=false ]
Thing topic RolloWZ {
Channels:
Type switch : blind "Wohnzimmer Rolladen" [ stateTopic="shellies/shellyswitch-55BD70/roller/0",
commandTopic="shellies/shellyswitch-55BD70/roller/0/command"]
Thing topic Temperatur_AM {
Channels:
Type number : temp "WZ Temperatur" [ stateTopic="zigbee2mqtt/Temperatur_WZ", commandTopic="zigbee2mqtt/Temperatur_WZ/temperature" ]
Type number : humi "WZ Luftfeuchtigkeit" [ stateTopic="zigbee2mqtt/Temperatur_WZ", commandTopic="zigbee2mqtt/Temperatur_WZ/humidity" ]
2019-02-25 19:29:52.510 [hingStatusInfoChangedEvent] - ‘mqtt:topic:PinkyMqtt:RolloWZ’ changed from INITIALIZING to ONLINE
The logfile gives ok for initialization, but no events are logged at all.
Is there anybody here who is using it already to open/close the blinds and could share his broker/things/items configuration with me?
regards
