If the line with the Shelly is switched off, this information is output every minute.
2024-11-30 17:33:29.357 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'shelly:shellyem:ShellyEM_PV' changed from OFFLINE (COMMUNICATION_ERROR): Verbindung zu Gerät fehlgeschlagenh: API Timeout for to ONLINE (CONFIGURATION_PENDING): Device is initializing or in sleep mode.
2024-11-30 17:33:32.449 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'shelly:shellyem:ShellyEM_PV' changed from ONLINE (CONFIGURATION_PENDING): Device is initializing or in sleep mode. to OFFLINE (COMMUNICATION_ERROR): Verbindung zu Gerät fehlgeschlagenh: NoRouteToHostException: No route to host
2024-11-30 17:34:32.452 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'shelly:shellyem:ShellyEM_PV' changed from OFFLINE (COMMUNICATION_ERROR): Verbindung zu Gerät fehlgeschlagenh: NoRouteToHostException: No route to host to ONLINE (CONFIGURATION_PENDING): Device is initializing or in sleep mode.
2024-11-30 17:34:35.568 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'shelly:shellyem:ShellyEM_PV' changed from ONLINE (CONFIGURATION_PENDING): Device is initializing or in sleep mode. to OFFLINE (COMMUNICATION_ERROR): Verbindung zu Gerät fehlgeschlagenh: NoRouteToHostException: No route to host
2024-11-30 17:35:35.573 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'shelly:shellyem:ShellyEM_PV' changed from OFFLINE (COMMUNICATION_ERROR): Verbindung zu Gerät fehlgeschlagenh: NoRouteToHostException: No route to host to ONLINE (CONFIGURATION_PENDING): Device is initializing or in sleep mode.
2024-11-30 17:35:38.689 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'shelly:shellyem:ShellyEM_PV' changed from ONLINE (CONFIGURATION_PENDING): Device is initializing or in sleep mode. to OFFLINE (COMMUNICATION_ERROR): Verbindung zu Gerät fehlgeschlagenh: NoRouteToHostException: No route to host
