I am running a freshly installed OH3 (openhabian) install 3.1.0 on a Raspberry4 2GB + SSD. I have replicated my old 2.5 installation but build everything from scratch in parallel.
Everything works but somehow my Shelly-Binding crashes after a while. I am running Shelly 2.5’s to control and automate my roller-shutters via the Astro Binding.
The rule is working properly but the shelly control gets lost. Other Z-wave devices work with the same rule without issues. I also observe that there are no Shelly events in the log (frontail) anymore until openhab gets restarted…
Can anyone help me to discover the root cause?
Should I use MQTT controls instead of the binding?
I can’t help with the specific problem beyond saying that the Shelly binding works just fine for me. But I’ve only got the one simple Shelly 1 switch.
You might get more information by putting the Shelly binding into debug logging and see if it outputs something useful. One would think that if something was going wrong though that it would generate an error log.
Given that the logging is handled completely independently from the bindings I see no reason why it should work for one and not the others unless the name of the logger you are using is wrong.
