there is no password id you don‘t set one in the device UI
are you able to access the Web UI, did you setup the correct WiFi?
Yes,
not at first, but when i once push the button i can access the webUI from my local network via entering the IP in my browser
The devices are also correctly connected via my WiFi (Thats also the way i can access the WebUI)
When i push the “Scan” button in Shelly-Binding during the phase where the WebUI is permanently reachable, also no device gets discovered …
Sidenote:
I set my shellys to a static ip in my network but not via their shelly ui, instead i did it in my router-settings (like i always do)
Additionaly i think i did not mention by now, that my openHAB is running on TrueNAS SCALE in Kubernetes/DockerCompose
Can this cause problems?
Are there any ports i have to publish?
please continue the discussion here:
I need a DEBUG log
Thanks for taking the time
I will post there …
