I have a problem with a shelly uni
It won’t go online.
09:19:59.995 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyuni-mcserver: Thing name derived from UID shelly:shellyuni:MCServer
09:19:59.996 [TRACE] [ly.internal.handler.ShellyBaseHandler] - shellyuni-mcserver: updateInterval = 60s -> skipCount = 20
09:19:59.997 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyuni-mcserver: Device config: IP address=192.168.110.15, HTTP user/password=jan/***, update interval=60
09:19:59.998 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyuni-mcserver: Configured Events: Button: false, Switch (on/off): false, Push: false, Roller: true, Sensor: true, CoIoT: true, Enable AutoCoIoT: true
09:19:59.999 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyuni-mcserver: Start initializing for thing Shelly uni MCServer, type shellyuni, IP address 192.168.110.15, Gen2: false, CoIoT: true
09:19:59.999 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'shelly:shellyuni:MCServer' changed from INITIALIZING to UNKNOWN (CONFIGURATION_PENDING): Initializing or device in sleep mode.
09:20:00.000 [TRACE] [g.shelly.internal.api1.Shelly1HttpApi] - Shelly uni MCServer: HTTP GET for http://192.168.110.15/shelly
09:20:00.119 [TRACE] [g.shelly.internal.api1.Shelly1HttpApi] - Shelly uni MCServer: HTTP Response 200: {"type":"SHUNI-1","mac":"E8DB84D65793","auth":true,"fw":"20220809-125434/v1.12-g99f7e0b","discoverable":true,"longid":1,"num_outputs":2}
09:20:00.120 [TRACE] [.shelly.internal.api.ShellyHttpClient] - shellyuni-mcserver: HTTP GET for http://192.168.110.15/settings
09:20:00.162 [TRACE] [.shelly.internal.api.ShellyHttpClient] - shellyuni-mcserver: HTTP Response 200: {"device":{"type":"SHUNI-1","mac":"E8DB84D65793","hostname":"shellyuni-E8DB84D65793","num_outputs":2},"wifi_ap":{"enabled":false,"ssid":"shellyuni-E8DB84D65793","key":""},"wifi_sta":{"enabled":true,"ssid":"Sf133iot","ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"wifi_sta1":{"enabled":false,"ssid":null,"ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"ap_roaming":{"enabled":true,"threshold":-70},"mqtt": {"enable":true,"server":"192.168.133.10:1883","user":"","id":"shellyuni-E8DB84D65793","reconnect_timeout_max":60.000000,"reconnect_timeout_min":2.000000,"clean_session":true,"keep_alive":60,"max_qos":0,"retain":false,"update_period":30},"coiot": {"enabled":true,"update_period":15,"peer":""},"sntp":{"server":"be.pool.ntp.org","enabled":true},"login":{"enabled":true,"unprotected":false,"username":"jan"},"pin_code":"","name":"MCServer","fw":"20220809-125434/v1.12-g99f7e0b","factory_reset_from_switch":true,"discoverable":true,"build_info":{"build_id":"20220809-125434/v1.12-g99f7e0b","build_timestamp":"2022-08-09T12:54:34Z","build_version":"1.0"},"cloud":{"enabled":false,"connected":false},"timezone":"Europe/Brussels","lat":50.873440,"lng":4.414890,"tzautodetect":true,"tz_utc_offset":3600,"tz_dst":false,"tz_dst_auto":true,"time":"09:20","unixtime":1667204400,"debug_enable":false,"allow_cross_origin":false,"actions":{"active":false,"names":["out_on_url","out_off_url","btn_on_url","btn_off_url","longpush_url","shortpush_url","out_on_url","out_off_url","btn_on_url","btn_off_url","longpush_url","shortpush_url","adc_over_url","adc_under_url","report_url","report_url","report_url","ext_temp_over_url","ext_temp_under_url","ext_temp_over_url","ext_temp_under_url","ext_temp_over_url","ext_temp_under_url","ext_temp_over_url","ext_temp_under_url","ext_temp_over_url","ext_temp_under_url","ext_hum_over_url","ext_hum_under_url"]},"hwinfo":{"hw_revision":"prod-202101", "batch_id":0},"mode":"relay","longpush_time":800,"relays":[{"name":"Reset_MCServer","appliance_type":"General","ison":false,"has_timer":false,"default_state":"off","btn_type":"detached","btn_reverse":0,"auto_on":0.00,"auto_off":1.00,"schedule":false,"schedule_rules":[]},{"name":"Power_MCServer","appliance_type":"General","ison":false,"has_timer":false,"default_state":"off","btn_type":"detached","btn_reverse":0,"auto_on":0.00,"auto_off":1.00,"schedule":false,"schedule_rules":[]}],"adcs":[{"range":12,"offset":0.00,"relay_actions":[{"over_threshold":0,"over_act":"disabled","under_threshold":0,"under_act":"disabled"},{"over_threshold":0,"over_act":"disabled","under_threshold":0,"under_act":"disabled"}]}],"ext_sensors":{"temperature_unit":"C"},"ext_temperature":{"1":[{"overtemp_threshold_tC":0.0,"overtemp_threshold_tF":32.0,"undertemp_threshold_tC":0.0,"undertemp_threshold_tF":32.0,"overtemp_act":"disabled","undertemp_act":"disabled","offset_tC":0.0,"offset_tF":0.0},{"overtemp_threshold_tC":0.0,"overtemp_threshold_tF":32.0,"undertemp_threshold_tC":0.0,"undertemp_threshold_tF":32.0,"overtemp_act":"disabled","undertemp_act":"disabled","offset_tC":0.0,"offset_tF":0.0}],"0":[{"overtemp_threshold_tC":0.0,"overtemp_threshold_tF":32.0,"undertemp_threshold_tC":0.0,"undertemp_threshold_tF":32.0,"overtemp_act":"disabled","undertemp_act":"disabled","offset_tC":0.0,"offset_tF":0.0},{"overtemp_threshold_tC":0.0,"overtemp_threshold_tF":32.0,"undertemp_threshold_tC":0.0,"undertemp_threshold_tF":32.0,"overtemp_act":"disabled","undertemp_act":"disabled","offset_tC":0.0,"offset_tF":0.0}]},"ext_humidity":null,"eco_mode_enabled":false}
09:20:00.170 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyuni-mcserver: Unable to initialize: API Timeout for , retrying later
09:20:00.171 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shellyuni-mcserver: Update status job started, interval=20*3=60sec.
Can someone point me in the right direction to get this working?
thx.
