Maybe this is already known but I couldnt find anything on this.
I have a plus plug S which I upgraded to 1.4.4
Now I cant seem to control the relais anymore. Also the status of thw relais is no longer reported. However the measurements are correctly received by openhab.
I tried enabling debug logging. However I cant find any entries relaited to the relais of this thing.
Okay strange I just did an update of Oj from 4.3.0 to 4.3.1 and now its woeking again. Though there was nothing relatwd in the release notes. Guess there was some issue on the websocket not being correctly established or so.
@tnemrap Update: got everything set up.
While a good idea, the only channel I see on my pro3m is temperature, and nothing else.
However, I did managed to get the json to add compatibility for the Shelly devices and shared it in the matter thread.
We likely wonāt see as many channels through matter as we saw in the Shelly binding though, at least I have a feeling that not everything can be exposed. Letās see how it goes.
But with my 10+ Shelly devices it should be a sizable update to our matter binding
Iām experimenting with the Shelly Plus RGBW PM and the official Shelly binding.
How can I switch the Shelly on or off?
I tried sending the brightness value 0 but the Shelly doesnāt accept that. What other options are there?
If the Shelly is off and I send a value >0, the Shelly switches on.
Why not try the matter bridge with the Shelly plugin? Since itās a dimmer, Iām pretty sure I read that Dan already has the dimmer function working.
Or maybe it was the colorā¦?
edit:
nope, dimmer, here:
levelcontrol-level Dimmer Dimmer Sets the level of the light Light
More info here:
and the read me here:
This isnāt a āsolutionā per se, because the matter protocol isnāt exposing nearly as many channels as the shelly binding. not by a long shot. But at least we can help push the matter binding forward by exposing shelly devices there hehe
Upon second reading, this is an Off topic. If unwelcome I will delete this post, please just let me know and I will do so.
Strange. The binding found the Shelly and suggested it.
I can create and operate the items. The RGBW-values āāare also correct.
Only switching it off doesnāt work
@markus7017 happy new year!
My (second) em3pro just crashed again and needed to be power cycled. I am now quite certain this is caused by the Shelly binding. The only way Iāve found that reduces or limits this is by disabling the thing in openHAB all together, or isolating the device in my network.
My logs still donāt show anything, but Iām not very good at this - another user previously shared his logs with a recurrent/constant call to the device.
It this is related, do you think that maybe there could be a fix?
