Doesnāt work either. Items are not getting updated unless I enable Shelly and restart Binding while LED is flashing. Just waited 3hrs! When I activate ShellyHT by pushing the button, device is accessible via WI but still no item is being updated. Iām running device with FW 20200309-104344/v1.6.0@43056d58 and OpenHAB 2.5.5-Snapshot. Really weird as Shelly Plug-s are working fine.
One more thing. My ShellyHT LED starts - after I had pushed the button - flashing slowly and than adter few seconds itās flashing faster. Do you experiemce the same`?
Thatās weird as I do have got in accident 2 replacements and tested both and both do flash slow and fast afterward and than stop after a certain time :-/
OK, you have configured them manually, while I used PaperUI (which I usually donāt like to) so I will doublecheck this. Do you have to configure also a bridge and do you use plug-s as well? Because if I start configuring one Shelly by file, I would like to keep all common
Thanks for prompt reply. I have remove Thing from PaperUI and created a valid entry in my things, following your sample (mine is also in our bedroom )
Now I have to be patient if any data is being updated. I hope it doesnāt matter that I switched off shelly-cloud (which I donāt like to use) as I prefer to keep my data (even just temp/humidity) in private.
I had to wake ht up, to get this found as device in inbox. Than I save my things-file and new device disappeared from inbox while added as thing. This prooves I copied entry correctly as device is shown as online because of this and items have been filled. Now I have to wait for update :-/ and Iām very good in being patient
I just go back to my Version 2.5.4 SS with Shelly Binding de-installed, removed things from Config and āmigratedā this to 2.5.4 stable to be on same version.
Have you installed Shelly Binding from Stable Version or the Dev. Version?
I just have installed included Shelly Binding (as first test) and have added only HT to things. Again waiting for Update while I try to force some temperature difference
Imagine if this device will appear than online, while right now itās unkown :-/
