Hi @Oliver2,
Here is the log, seems the trigger is well received, but I see some java exception
2022-01-25 19:04:03.757 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer2-3c6105e405c7: 18 CoAP sensor updates received
2022-01-25 19:04:03.760 [DEBUG] [ly.internal.coap.ShellyCoIoTVersion2] - shellydimmer2-3c6105e405c7: Updating meter:currentWatts with 28.82
2022-01-25 19:04:03.769 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel relay#brightness$Switch updated with OFF (type class org.openhab.core.library.types.OnOffType).
2022-01-25 19:04:03.776 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel relay#brightness$Value updated with 0 % (type class org.openhab.core.library.types.QuantityType).
2022-01-25 19:04:03.778 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer2-3c6105e405c7: 2 channels updated from CoIoT status, serial=64769
2022-01-25 19:04:04.307 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel device#heartBeat updated with 2022-01-25T19:04:04.000+0100 (type class org.openhab.core.library.types.DateTimeType).
2022-01-25 19:04:04.315 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel device#uptime updated with 231574 s (type class org.openhab.core.library.types.QuantityType).
2022-01-25 19:04:04.320 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellydimmer2-3c6105e405c7: Unable to refresh status: Unable to update status
java.lang.IllegalArgumentException: Timestamp value 0 is invalid
at org.openhab.binding.shelly.internal.util.ShellyUtils.getTimestamp(ShellyUtils.java:292) ~[?:?]
at org.openhab.binding.shelly.internal.handler.ShellyComponents.updateMeters(ShellyComponents.java:137) ~[?:?]
at org.openhab.binding.shelly.internal.handler.ShellyBaseHandler.refreshStatus(ShellyBaseHandler.java:421) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) [?:?]
2022-01-25 19:04:05.279 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer2-3c6105e405c7: CoIoT Message from /192.168.4.218:5683 (MID=56447): {"G":[[0,9103,0],[0,1101,0],[0,5101,100],[0,2101,0],[0,2102,""],[0,2103,7],[0,2201,0],[0,2202,"S"],[0,2203,8],[0,4101,0.00],[0,4103,0],[0,6102,0],[0,6109,0.00],[0,6104,0],[0,3104,46.40],[0,3105,115.52],[0,6101,0],[0,9101,"white"]]}
2022-01-25 19:04:05.280 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel device#heartBeat updated with 2022-01-25T19:04:05.000+0100 (type class org.openhab.core.library.types.DateTimeType).
2022-01-25 19:04:05.281 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer2-3c6105e405c7: CoIoT Sensor data {"G":[[0,9103,0],[0,1101,0],[0,5101,100],[0,2101,0],[0,2102,""],[0,2103,7],[0,2201,0],[0,2202,"S"],[0,2203,8],[0,4101,0.00],[0,4103,0],[0,6102,0],[0,6109,0.00],[0,6104,0],[0,3104,46.40],[0,3105,115.52],[0,6101,0],[0,9101,"white"]]} (serial=65025)
2022-01-25 19:04:05.282 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer2-3c6105e405c7: 18 CoAP sensor updates received
2022-01-25 19:04:05.284 [DEBUG] [ly.internal.coap.ShellyCoIoTVersion2] - shellydimmer2-3c6105e405c7: Updating meter:currentWatts with 0.0
2022-01-25 19:04:05.285 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel meter#currentWatts updated with 0 W (type class org.openhab.core.library.types.QuantityType).
2022-01-25 19:04:05.287 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel meter#lastUpdate updated with 2022-01-25T19:04:05.000+0100 (type class org.openhab.core.library.types.DateTimeType).
2022-01-25 19:04:05.288 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer2-3c6105e405c7: 2 channels updated from CoIoT status, serial=65025
2022-01-25 19:04:05.826 [INFO ] [org.openhab.core.model.script.Test ] - Event: SHORT_PRESSED
2022-01-25 19:04:05.827 [INFO ] [org.openhab.core.model.script.test ] - 2 SHORT_PRESSED
2022-01-25 19:04:05.828 [INFO ] [ipt.lights:Light Office Override OFF] - Light Office Timer Override OFF. Automatic switch OFF timer active
2022-01-25 19:04:06.875 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer2-3c6105e405c7: CoIoT Message from /192.168.4.218:5683 (MID=56448): {"G":[[0,9103,0],[0,1101,1],[0,5101,100],[0,2101,0],[0,2102,""],[0,2103,7],[0,2201,0],[0,2202,"S"],[0,2203,10],[0,4101,0.00],[0,4103,0],[0,6102,0],[0,6109,0.00],[0,6104,0],[0,3104,46.40],[0,3105,115.52],[0,6101,0],[0,9101,"white"]]}
2022-01-25 19:04:06.879 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel device#heartBeat updated with 2022-01-25T19:04:06.000+0100 (type class org.openhab.core.library.types.DateTimeType).
2022-01-25 19:04:06.883 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer2-3c6105e405c7: CoIoT Sensor data {"G":[[0,9103,0],[0,1101,1],[0,5101,100],[0,2101,0],[0,2102,""],[0,2103,7],[0,2201,0],[0,2202,"S"],[0,2203,10],[0,4101,0.00],[0,4103,0],[0,6102,0],[0,6109,0.00],[0,6104,0],[0,3104,46.40],[0,3105,115.52],[0,6101,0],[0,9101,"white"]]} (serial=65281)
2022-01-25 19:04:06.887 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer2-3c6105e405c7: 18 CoAP sensor updates received
2022-01-25 19:04:06.890 [DEBUG] [ly.internal.coap.ShellyCoIoTProtocol] - shellydimmer2-3c6105e405c7: Trigger event S
2022-01-25 19:04:06.892 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellydimmer2-3c6105e405c7: Update button state with S/SHORT_PRESSED
2022-01-25 19:04:06.894 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellydimmer2-3c6105e405c7: Send event relay#button2 to channel SHORT_PRESSED
2022-01-25 19:04:06.895 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel relay#lastUpdate updated with 2022-01-25T19:04:06.000+0100 (type class org.openhab.core.library.types.DateTimeType).
2022-01-25 19:04:06.897 [DEBUG] [ly.internal.coap.ShellyCoIoTVersion2] - shellydimmer2-3c6105e405c7: Updating meter:currentWatts with 0.0
2022-01-25 19:04:06.897 [INFO ] [org.openhab.core.model.script.Test ] - Event: SHORT_PRESSED
2022-01-25 19:04:06.899 [INFO ] [org.openhab.core.model.script.test ] - 2 SHORT_PRESSED
2022-01-25 19:04:06.901 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel meter#lastUpdate updated with 2022-01-25T19:04:06.000+0100 (type class org.openhab.core.library.types.DateTimeType).
2022-01-25 19:04:06.904 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel relay#brightness$Switch updated with ON (type class org.openhab.core.library.types.OnOffType).
2022-01-25 19:04:06.909 [INFO ] [ipt.lights:Light Office Override OFF] - Light Office Timer Override OFF. Automatic switch OFF timer active
2022-01-25 19:04:06.907 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel relay#brightness$Value updated with 100 % (type class org.openhab.core.library.types.QuantityType).
2022-01-25 19:04:06.911 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel relay#eventCount2 updated with 10 (type class org.openhab.core.library.types.DecimalType).
2022-01-25 19:04:06.913 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer2-3c6105e405c7: 4 channels updated from CoIoT status, serial=65281
2022-01-25 19:04:07.352 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel device#heartBeat updated with 2022-01-25T19:04:07.000+0100 (type class org.openhab.core.library.types.DateTimeType).
2022-01-25 19:04:07.364 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel device#uptime updated with 231577 s (type class org.openhab.core.library.types.QuantityType).
2022-01-25 19:04:07.369 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellydimmer2-3c6105e405c7: Unable to refresh status: Unable to update status
2022-01-25 19:04:09.281 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer2-3c6105e405c7: CoIoT Message from /192.168.4.218:5683 (MID=56449): {"G":[[0,9103,0],[0,1101,1],[0,5101,100],[0,2101,0],[0,2102,""],[0,2103,7],[0,2201,0],[0,2202,"S"],[0,2203,10],[0,4101,28.42],[0,4103,0],[0,6102,0],[0,6109,0.00],[0,6104,0],[0,3104,46.32],[0,3105,115.37],[0,6101,0],[0,9101,"white"]]}
2022-01-25 19:04:09.283 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel device#heartBeat updated with 2022-01-25T19:04:09.000+0100 (type class org.openhab.core.library.types.DateTimeType).
2022-01-25 19:04:09.284 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer2-3c6105e405c7: CoIoT Sensor data {"G":[[0,9103,0],[0,1101,1],[0,5101,100],[0,2101,0],[0,2102,""],[0,2103,7],[0,2201,0],[0,2202,"S"],[0,2203,10],[0,4101,28.42],[0,4103,0],[0,6102,0],[0,6109,0.00],[0,6104,0],[0,3104,46.32],[0,3105,115.37],[0,6101,0],[0,9101,"white"]]} (serial=2)
2022-01-25 19:04:09.286 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer2-3c6105e405c7: 18 CoAP sensor updates received
2022-01-25 19:04:09.287 [DEBUG] [ly.internal.coap.ShellyCoIoTVersion2] - shellydimmer2-3c6105e405c7: Updating meter:currentWatts with 28.42
2022-01-25 19:04:09.290 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel meter#currentWatts updated with 28.42 W (type class org.openhab.core.library.types.QuantityType).
2022-01-25 19:04:09.292 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel meter#lastUpdate updated with 2022-01-25T19:04:09.000+0100 (type class org.openhab.core.library.types.DateTimeType).
2022-01-25 19:04:09.294 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer2-3c6105e405c7: 2 channels updated from CoIoT status, serial=2
2022-01-25 19:04:09.667 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer2-3c6105e405c7: CoIoT Message from /192.168.4.218:5683 (MID=56450): {"G":[[0,9103,0],[0,1101,1],[0,5101,100],[0,2101,0],[0,2102,""],[0,2103,7],[0,2201,1],[0,2202,"S"],[0,2203,10],[0,4101,28.42],[0,4103,0],[0,6102,0],[0,6109,0.00],[0,6104,0],[0,3104,46.32],[0,3105,115.37],[0,6101,0],[0,9101,"white"]]}
2022-01-25 19:04:09.668 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer2-3c6105e405c7: CoIoT Sensor data {"G":[[0,9103,0],[0,1101,1],[0,5101,100],[0,2101,0],[0,2102,""],[0,2103,7],[0,2201,1],[0,2202,"S"],[0,2203,10],[0,4101,28.42],[0,4103,0],[0,6102,0],[0,6109,0.00],[0,6104,0],[0,3104,46.32],[0,3105,115.37],[0,6101,0],[0,9101,"white"]]} (serial=258)
2022-01-25 19:04:09.669 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer2-3c6105e405c7: 18 CoAP sensor updates received
2022-01-25 19:04:09.670 [DEBUG] [ly.internal.coap.ShellyCoIoTVersion2] - shellydimmer2-3c6105e405c7: Updating meter:currentWatts with 28.42
2022-01-25 19:04:09.674 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel relay#input2 updated with ON (type class org.openhab.core.library.types.OnOffType).
2022-01-25 19:04:09.675 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer2-3c6105e405c7: 1 channels updated from CoIoT status, serial=258
2022-01-25 19:04:10.404 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel device#heartBeat updated with 2022-01-25T19:04:10.000+0100 (type class org.openhab.core.library.types.DateTimeType).
2022-01-25 19:04:10.412 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel device#uptime updated with 231580 s (type class org.openhab.core.library.types.QuantityType).
2022-01-25 19:04:10.420 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel relay#lastEvent2 updated with L (type class org.openhab.core.library.types.StringType).
2022-01-25 19:04:10.421 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel relay#eventCount2 updated with 11 (type class org.openhab.core.library.types.DecimalType).
2022-01-25 19:04:10.425 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellydimmer2-3c6105e405c7: Unable to refresh status: Unable to update status
2022-01-25 19:04:10.470 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer2-3c6105e405c7: CoIoT Message from /192.168.4.218:5683 (MID=56451): {"G":[[0,9103,0],[0,1101,1],[0,5101,100],[0,2101,0],[0,2102,""],[0,2103,7],[0,2201,1],[0,2202,"L"],[0,2203,11],[0,4101,28.42],[0,4103,0],[0,6102,0],[0,6109,0.00],[0,6104,0],[0,3104,46.32],[0,3105,115.37],[0,6101,0],[0,9101,"white"]]}
2022-01-25 19:04:10.472 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer2-3c6105e405c7: CoIoT Sensor data {"G":[[0,9103,0],[0,1101,1],[0,5101,100],[0,2101,0],[0,2102,""],[0,2103,7],[0,2201,1],[0,2202,"L"],[0,2203,11],[0,4101,28.42],[0,4103,0],[0,6102,0],[0,6109,0.00],[0,6104,0],[0,3104,46.32],[0,3105,115.37],[0,6101,0],[0,9101,"white"]]} (serial=514)
2022-01-25 19:04:10.473 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer2-3c6105e405c7: 18 CoAP sensor updates received
2022-01-25 19:04:10.474 [DEBUG] [ly.internal.coap.ShellyCoIoTProtocol] - shellydimmer2-3c6105e405c7: Trigger event L
2022-01-25 19:04:10.476 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellydimmer2-3c6105e405c7: Update button state with L/LONG_PRESSED
2022-01-25 19:04:10.477 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellydimmer2-3c6105e405c7: Send event relay#button2 to channel LONG_PRESSED
2022-01-25 19:04:10.480 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel relay#lastUpdate updated with 2022-01-25T19:04:10.000+0100 (type class org.openhab.core.library.types.DateTimeType).
2022-01-25 19:04:10.482 [DEBUG] [ly.internal.coap.ShellyCoIoTVersion2] - shellydimmer2-3c6105e405c7: Updating meter:currentWatts with 28.42
2022-01-25 19:04:10.482 [INFO ] [org.openhab.core.model.script.Test ] - Event: LONG_PRESSED
2022-01-25 19:04:10.482 [INFO ] [org.openhab.core.model.script.test ] - 2 Long_PRESSED
2022-01-25 19:04:10.487 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel meter#lastUpdate updated with 2022-01-25T19:04:10.000+0100 (type class org.openhab.core.library.types.DateTimeType).
2022-01-25 19:04:10.490 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer2-3c6105e405c7: 1 channels updated from CoIoT status, serial=514
2022-01-25 19:04:11.693 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer2-3c6105e405c7: CoIoT Message from /192.168.4.218:5683 (MID=56452): {"G":[[0,9103,0],[0,1101,1],[0,5101,73],[0,2101,0],[0,2102,""],[0,2103,7],[0,2201,0],[0,2202,"L"],[0,2203,11],[0,4101,28.52],[0,4103,0],[0,6102,0],[0,6109,0.00],[0,6104,0],[0,3104,46.32],[0,3105,115.37],[0,6101,0],[0,9101,"white"]]}
2022-01-25 19:04:11.695 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel device#heartBeat updated with 2022-01-25T19:04:11.000+0100 (type class org.openhab.core.library.types.DateTimeType).
2022-01-25 19:04:11.697 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer2-3c6105e405c7: CoIoT Sensor data {"G":[[0,9103,0],[0,1101,1],[0,5101,73],[0,2101,0],[0,2102,""],[0,2103,7],[0,2201,0],[0,2202,"L"],[0,2203,11],[0,4101,28.52],[0,4103,0],[0,6102,0],[0,6109,0.00],[0,6104,0],[0,3104,46.32],[0,3105,115.37],[0,6101,0],[0,9101,"white"]]} (serial=770)
2022-01-25 19:04:11.699 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer2-3c6105e405c7: 18 CoAP sensor updates received
2022-01-25 19:04:11.702 [DEBUG] [ly.internal.coap.ShellyCoIoTVersion2] - shellydimmer2-3c6105e405c7: Updating meter:currentWatts with 28.52
2022-01-25 19:04:11.705 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel meter#currentWatts updated with 28.52 W (type class org.openhab.core.library.types.QuantityType).
2022-01-25 19:04:11.707 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel meter#lastUpdate updated with 2022-01-25T19:04:11.000+0100 (type class org.openhab.core.library.types.DateTimeType).
2022-01-25 19:04:11.712 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel relay#brightness$Value updated with 73 % (type class org.openhab.core.library.types.QuantityType).
2022-01-25 19:04:11.716 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel relay#input2 updated with OFF (type class org.openhab.core.library.types.OnOffType).
2022-01-25 19:04:11.718 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer2-3c6105e405c7: 4 channels updated from CoIoT status, serial=770
2022-01-25 19:04:11.719 [INFO ] [ipt.lights:Light Office Override OFF] - Light Office Timer Override OFF. Automatic switch OFF timer active
2022-01-25 19:04:13.152 [INFO ] [ghts:Light Office Override On Switch] - Light Office Timer Override. No Automatic switch OFF
2022-01-25 19:04:13.459 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel device#heartBeat updated with 2022-01-25T19:04:13.000+0100 (type class org.openhab.core.library.types.DateTimeType).
2022-01-25 19:04:13.473 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel device#uptime updated with 231583 s (type class org.openhab.core.library.types.QuantityType).
2022-01-25 19:04:13.479 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel relay#input2 updated with ON (type class org.openhab.core.library.types.OnOffType).
2022-01-25 19:04:13.481 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel relay#lastEvent2 updated with S (type class org.openhab.core.library.types.StringType).
2022-01-25 19:04:13.483 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel relay#eventCount2 updated with 12 (type class org.openhab.core.library.types.DecimalType).
2022-01-25 19:04:13.484 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel meter#currentWatts updated with 20.27 W (type class org.openhab.core.library.types.QuantityType).
2022-01-25 19:04:13.486 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellydimmer2-3c6105e405c7: Unable to refresh status: Unable to update status
2022-01-25 19:04:13.914 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer2-3c6105e405c7: CoIoT Message from /192.168.4.218:5683 (MID=56453): {"G":[[0,9103,0],[0,1101,1],[0,5101,100],[0,2101,0],[0,2102,""],[0,2103,7],[0,2201,0],[0,2202,"S"],[0,2203,13],[0,4101,20.27],[0,4103,0],[0,6102,0],[0,6109,0.00],[0,6104,0],[0,3104,46.24],[0,3105,115.23],[0,6101,0],[0,9101,"white"]]}
2022-01-25 19:04:13.916 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer2-3c6105e405c7: CoIoT Sensor data {"G":[[0,9103,0],[0,1101,1],[0,5101,100],[0,2101,0],[0,2102,""],[0,2103,7],[0,2201,0],[0,2202,"S"],[0,2203,13],[0,4101,20.27],[0,4103,0],[0,6102,0],[0,6109,0.00],[0,6104,0],[0,3104,46.24],[0,3105,115.23],[0,6101,0],[0,9101,"white"]]} (serial=1026)
2022-01-25 19:04:13.917 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer2-3c6105e405c7: 18 CoAP sensor updates received
2022-01-25 19:04:13.919 [DEBUG] [ly.internal.coap.ShellyCoIoTProtocol] - shellydimmer2-3c6105e405c7: Trigger event S
2022-01-25 19:04:13.920 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellydimmer2-3c6105e405c7: Update button state with S/SHORT_PRESSED
2022-01-25 19:04:13.921 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellydimmer2-3c6105e405c7: Send event relay#button2 to channel SHORT_PRESSED
2022-01-25 19:04:13.925 [INFO ] [org.openhab.core.model.script.test ] - 2 SHORT_PRESSED
2022-01-25 19:04:13.925 [INFO ] [org.openhab.core.model.script.Test ] - Event: SHORT_PRESSED
2022-01-25 19:04:13.925 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel relay#lastUpdate updated with 2022-01-25T19:04:13.000+0100 (type class org.openhab.core.library.types.DateTimeType).
2022-01-25 19:04:13.928 [DEBUG] [ly.internal.coap.ShellyCoIoTVersion2] - shellydimmer2-3c6105e405c7: Updating meter:currentWatts with 20.27
2022-01-25 19:04:13.931 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel meter#lastUpdate updated with 2022-01-25T19:04:13.000+0100 (type class org.openhab.core.library.types.DateTimeType).
2022-01-25 19:04:13.935 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel relay#brightness$Value updated with 100 % (type class org.openhab.core.library.types.QuantityType).
2022-01-25 19:04:13.938 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel relay#eventCount2 updated with 13 (type class org.openhab.core.library.types.DecimalType).
2022-01-25 19:04:13.940 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer2-3c6105e405c7: Channel relay#input2 updated with OFF (type class org.openhab.core.library.types.OnOffType).
2022-01-25 19:04:13.941 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer2-3c6105e405c7: 4 channels updated from CoIoT status, serial=1026
2022-01-25 19:04:13.943 [INFO ] [ipt.lights:Light Office Override OFF] - Light Office Timer Override OFF. Automatic switch OFF timer active
