I’m having some issues setting the color temp for a shelly duo GU10,
I’d like to ad 2 channels but the documentation is a bit wierd:
white Color settings: only valid in WHITE mode
temperature Number r/w color temperature (K): 0…100% or 3000…6500
brightness Dimmer Brightness: 0…100% or 0…100
if i do the brightness alone it works, if i do the temperature alone i get the 3000-6500 view with a non working slider.
but since one is a number and the other is a dimmer I’ve got no clue.
plus do i need a transformation to get the temperature to use the percentage in the gui but shows 3000-6500?
From the thing you say add equipment to model and add all channels.
Then on the thing, open the temperature, say „add metadata“ and chose default widget (all three types. Stand alone, row, cell) ans klick the Advanced checkbox.
