Environment:
openHAB 3.2-M4 on RaspBerry (latest versions of all SW)
Shelly H&T Sensor (with Power Supply - not battery) - also latest firmware installed
Problem:
The device is not discovered when I do a scan, even if done repeatedly - of course I always wake up the device. When added manually, the device stays in status CONFIG PENDING forever.
What to do, to get this item fully defined and working in openHAB
Note: I am also using homebridge and the shelly-add-on. The device got recognized, configured and exposed to HomeKit instantly and correctly without any problem.
Yes, I did. When I wake up the device I can access it with its web interface. As said, I am also using homebridge and the shelly-plug-in there detected and configured the device correctly and instantly.
in openHAB I deleted the thing and created it a couple of times manually. Even when awake, openHAB does not detect the device. So I am stuck.
Right now, I can’t even discover the thing. I have to add it manually, but only the alarm and signal strength shown as channels, temperature is missing WTF?. I’m getting really frustrated with openhab right now…
