Hi community,
I have several Shelly Plus 2PM devices as shutter installed. I recently noticed that the position value (roller#rollerpos) is no longer updated when I use the “UP” or “DOWN” buttons on the roller#control item.
The same behavior occurs when I use the “UP” and “DOWN” buttons in the Shelly Device interface. Even then the roller#rollerpos in OH isn’t updated.
Is this behavior known?
OH: 5.2.3
Shelly FW: 1.7.6
Update:
When I use the “UP” or “DOWN” button and then press “STOP” the position value is updated. Only when I let the rollershutter go all the way up or all the way down without pressing the stop button the position value is not updated.
Log (UP & DOWN & STOP):
| ant 08:34:22.193 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyRelayHandler | shellyplus2pm-30c92281ab70: Roller command/position DOWN |
| ant 08:34:22.193 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyRelayHandler | shellyplus2pm-30c92281ab70: Closing roller |
| ant 08:34:22.469 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334566247E9,“cover:0”:{“apower”:1.6}}} |
| ant 08:34:22.470 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 1.60 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:34:22.516 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334566252E9,“cover:0”:{“apower”:96.2}}} |
| ant 08:34:22.517 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 96.20 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:34:22.554 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334566253E9,“cover:0”:{“source”:“HTTP_in”,“state”:“closing”,“move_timeout”:60.0,“move_started_at”:1.79334566253E9}}} |
| ant 08:34:22.574 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334566257E9,“cover:0”:{“apower”:167.8}}} |
| ant 08:34:22.574 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 167.80 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:34:22.618 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334566262E9,“cover:0”:{“apower”:178.4}}} |
| ant 08:34:22.618 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 178.40 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:34:22.772 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 180.50 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:34:26.027 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyRelayHandler | shellyplus2pm-30c92281ab70: Roller command/position STOP |
| ant 08:34:26.027 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyRelayHandler | shellyplus2pm-30c92281ab70: Stop roller |
| ant 08:34:26.362 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334566634E9,“cover:0”:{“source”:“HTTP_in”,“state”:“stopped”,“apower”:0.0,“current”:0.0,“pf”:0.0,“current_pos”:88}}} |
| ant 08:34:26.362 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Update roller position to 88/12, state=stop |
| ant 08:34:26.362 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel roller#control updated with 12 % (type class org.openhab.core.library.types.QuantityType). |
| ant 08:34:26.363 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel roller#rollerpos updated with 88 % (type class org.openhab.core.library.types.QuantityType). |
| ant 08:34:26.363 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 0 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:34:28.821 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Update roller position to 88/12, state=stop |
| ant 08:34:34.891 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Update roller position to 88/12, state=stop |
Log (UP & DOWN [no stop!]):
| ant 08:37:51.109 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyRelayHandler | shellyplus2pm-30c92281ab70: Roller command/position UP |
| ant 08:37:51.109 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyRelayHandler | shellyplus2pm-30c92281ab70: Open roller |
| ant 08:37:51.439 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334587142E9,“cover:0”:{“source”:“HTTP_in”,“state”:“opening”,“move_timeout”:60.0,“move_started_at”:1.79334587142E9}}} |
| ant 08:37:51.497 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334587146E9,“cover:0”:{“apower”:112.6}}} |
| ant 08:37:51.498 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 112.60 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:37:51.498 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334587149E9,“cover:0”:{“apower”:160.2}}} |
| ant 08:37:51.499 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 160.20 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:37:51.534 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334587154E9,“cover:0”:{“apower”:179.6}}} |
| ant 08:37:51.535 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 179.60 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:37:53.109 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 182.10 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:37:53.984 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334587399E9,“cover:0”:{“apower”:158.9}}} |
| ant 08:37:53.985 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 158.90 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:37:54.034 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334587404E9,“cover:0”:{“apower”:116.4}}} |
| ant 08:37:54.035 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 116.40 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:37:54.089 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334587409E9,“cover:0”:{“apower”:103.6}}} |
| ant 08:37:54.090 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 103.60 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:37:54.984 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334587499E9,“cover:0”:{“apower”:108.9}}} |
| ant 08:37:54.984 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 108.90 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:37:56.982 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334587699E9,“cover:0”:{“apower”:123.4}}} |
| ant 08:37:56.982 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 123.40 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:37:57.034 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334587704E9,“cover:0”:{“apower”:135.2}}} |
| ant 08:37:57.034 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 135.20 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:37:57.082 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334587709E9,“cover:0”:{“apower”:142.7}}} |
| ant 08:37:57.083 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 142.70 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:37:57.141 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334587714E9,“cover:0”:{“apower”:151.0}}} |
| ant 08:37:57.141 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 151 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:37:57.185 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334587719E9,“cover:0”:{“apower”:121.6}}} |
| ant 08:37:57.185 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 121.60 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:37:57.237 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334587724E9,“cover:0”:{“apower”:38.8}}} |
| ant 08:37:57.237 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 38.80 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:37:57.282 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334587729E9,“cover:0”:{“apower”:7.8}}} |
| ant 08:37:57.283 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 7.80 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:37:57.334 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334587734E9,“cover:0”:{“apower”:1.7}}} |
| ant 08:37:57.335 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 1.70 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:37:57.388 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334587739E9,“cover:0”:{“apower”:0.0}}} |
| ant 08:37:57.389 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 0 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:37:57.533 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334587754E9,“cover:0”:{“apower”:33.6}}} |
| ant 08:37:57.534 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 33.60 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:37:57.583 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334587759E9,“cover:0”:{“apower”:49.0}}} |
| ant 08:37:57.583 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 49 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:37:57.685 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334587769E9,“cover:0”:{“apower”:54.2}}} |
| ant 08:37:57.686 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 54.20 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:37:57.738 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334587774E9,“cover:0”:{“apower”:62.0}}} |
| ant 08:37:57.738 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 62 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:37:57.783 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334587779E9,“cover:0”:{“apower”:69.0}}} |
| ant 08:37:57.783 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 69 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:37:57.832 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334587784E9,“cover:0”:{“apower”:76.6}}} |
| ant 08:37:57.832 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 76.60 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:37:57.882 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334587789E9,“cover:0”:{“apower”:85.5}}} |
| ant 08:37:57.882 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 85.50 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:37:57.934 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334587794E9,“cover:0”:{“apower”:93.8}}} |
| ant 08:37:57.934 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 93.80 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:37:57.982 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334587799E9,“cover:0”:{“apower”:102.3}}} |
| ant 08:37:57.983 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 102.30 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:37:58.032 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334587804E9,“cover:0”:{“apower”:110.9}}} |
| ant 08:37:58.032 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 110.90 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:37:58.182 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334587819E9,“cover:0”:{“apower”:102.6}}} |
| ant 08:37:58.182 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 102.60 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:37:58.282 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334587829E9,“cover:0”:{“apower”:56.1}}} |
| ant 08:37:58.282 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 56.10 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:37:58.332 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334587834E9,“cover:0”:{“apower”:14.8}}} |
| ant 08:37:58.332 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 14.80 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:37:58.381 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334587839E9,“cover:0”:{“apower”:3.6}}} |
| ant 08:37:58.382 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 3.60 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:37:58.432 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334587844E9,“cover:0”:{“apower”:1.4}}} |
| ant 08:37:58.432 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 1.40 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:37:58.482 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334587849E9,“cover:0”:{“apower”:0.0}}} |
| ant 08:37:58.482 | DEBUG | org.openhab.binding.shelly.internal.handler.ShellyBaseHandler | shellyplus2pm-30c92281ab70: Channel meter#currentWatts updated with 0 W (type class org.openhab.core.library.types.QuantityType). |
| ant 08:37:58.701 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334587869E9,“cover:0”:{“source”:“limit_switch”,“state”:“open”,“apower”:0.0,“current”:0.0,“pf”:0.0,“current_pos”:100}}} |
| ant 08:38:00.005 | DEBUG | org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc | Shelly Rollade WZ links: NotifyStatus update received: {“src”:“shellyplus2pm-30c92281ab70”,“dst”:“ohshelly-30c92281ab70-47119”,“method”:“NotifyStatus”,“params”:{“ts”:1.79334588E9,“cover:0”:{“aenergy”:{“total”:1966.424,“by_minute”:[262.291,0.0,0.0],“minute_ts”:1793345880}}}} |
