refreshing the thread: Shelly Binding - GU10 RGBW Spot - #3 by shorty707
i have a
- Shelly Plus RGBW PM - LED Controller with Power Meter
which was discovered correctly - with brigthness and color channel.
Problem to solve - working color light via homekit addon but first working standalone in openhab
1/ Dimmer item shelly:shellyplusrgbwpm:ecc9ff4d1e20:white#brightness using a openhab gui slider on a dimmeritem i get:
- moving the slider from more than 0% to 100% is working and it’s trasnfered to shelly (visible in shelly appy
- moving the slider to “0%” position has no influence on dimmer level in shelly app - it stays at the previous selected
Shelly rgb has always status ON - it;s not possible to turn it off using dimmer.
2/ There is of course no on off state channel for this device.
I have also a shellydimmer2 configured the same way and this dimmer is working well. Moving the slider to 0% shutdown the shelly and sends 0% dimmer level to shelly.
It seems to be a problem with implementation of shelly plus RGBW in the binding
there is a bug
