I have shelly shutters and need help making an item button
That as soon as I press it then the shutter will open / close at the% I set for it
I created a shellycloud.item file
Inside it I wrote
Is this Item something that existed before you made an xxx.items file? It looks like, from the name.
If so, delete your Item file entry, you do not want it defined in two places, especially when one is in error.
