How can I tell the Shelly TRV in openhab the current room temperature, which is received by me in openhab via any IoT?
I have seen that you can activate an endpoint in the sensor settings.
My idea would be to send this to the TRV at certain intervals using the HTTP binding. But how do I get the temperature variable into the HTTP GET command?
This might be errorprone as it measures the temperature next to the radiator, not the room temp.
I am not at home, so can’t prove next statement.
If I am not wrong, Shelly TRV‘s have an advanced channel for external temperature readings. If this is correct, link a temperature item to it and send your readings to it.
The Shelly Binding definitely does not provide this channel.
Would indeed be desirable for the future.
The TRV has its own temperature sensor, of course, but in my case the TRV is mounted at a corner where warm air collects and extreme temperature deviations occur that I cannot solve with an offset.
There is the possibility to communicate the temperature to the TRV via the HTTP API. I just need some advice on how to do this with the HTTP binding.
I do it via a rule triggered when the room temperature item changes and executing this short script:
> val theURLtoCall = "http://192.168.101.68/ext_t?temp="
> // Strip out the unit from the state
> var temp = (newState as Number).floatValue
> sendHttpGetRequest(theURLtoCall + temp)
