I have the new TRV from shelly and tried to enclose it into OH. Thing will be shown, but with an error message. After adding the device IP, the TRV is shown, but there are nor channels to be linked.
Is it needed to add the TRV into the binding by the developers of the binding? Do i need to do add aditional code?
igi
(Igor Jasan)
January 15, 2022, 8:17pm
#2
The support for the TRV is not yet included in the Shelly Binding version that is distributed with the official OH.
You need to install the DEV build. This includes the TRV support.
See Shelly Binding Thread:
I found a bug, please try the latest DEV build
Fixes/Features
Support for Shelly TRV (not fully tested)
Channel device#supplyVoltage re-added
Event types BUTTON | PERIODIC | SENSOR will not be posted to the alarm trigger channel
Categories to thing types and many channel types added (Metadata)
serviceName will be used instead of deviceName to avoid duplictate devices in the Inbox after changing Device Name in the Shelly settings
README updated
Please help testing and reviewing documentation.…
Thanks igi. Where can I find the DEV build and how to install.
igi
(Igor Jasan)
January 16, 2022, 1:13pm
#4
Please see the post I mentioned. Below the post is the link to the DEV version and the installation instructions under:
# Shelly Binding (org.openhab.binding.shelly)
This Binding implements control for the Shelly series of devices.
This includes sending commands to the devices as well as reading the device status and sensor data.
Author: Markus Michels (markus7017)
Check https://community.openhab.org/t/shelly-binding/ for more information, questions and contributing ideas. Any comments are welcome!
Also check section **Additional Information** at the end of the document.
This includes some general comments, information how to debug and request new features.
Please let me know if you have problems installing the new build or this doc can be improved.
DISCLAIMER: Please be ware, installing a SNAPSHOT or DEV build might impact the stability of your installation and cause backward compatibility issues. Do a full backup of your installation any time you do an update.
## General Notes
This file has been truncated. show original
markus7017
(Markus Michels)
January 17, 2022, 11:38pm
#5
