I just flash (successfully) a Shelly with Tasmota, simply question because I still looking for “small” (and cheap) solution to have two switches (contacts) to send MQTT to my oH server …
Is it possible to use the GPIO the Shelly have to connect them with push button and send (if contact is closed) a MQTT command? (I need two seperated contacts/GPIO’s) (Shelly seems to have 3 GPIO’s)
Andy disadantages now?
And shure, MQTT is also possible with Tasmota, but I ask to use 2 different GPIO’s from the Shelby to send 2 different MQTT commands (so I what switch was pushed). Is this possible, maybe only with the orig Firmware?
You mean the “Templates”, available in newest Tasmota Version?
Actual I try to flash, was successfull, but I can’t reach the Web GUI from Tasmota anymore, password not accepted :-(. Seems I have a typing error while setting the web password Can’t logion anymore …
How can I reset the Shelly? Find some hints like 40s ground to GPIO0 (done while USB connected: without succes).
New Flashing seems fine with “Atom” ("… uploading completed" / success), but still the old IP address (and web-password) etc. is used, so I think I have to reset the Shelly before I can flash …
But how?
Update: I use this tool “nodemcu-flasher-master” which should clean the flash from the Shelly (or?).
After this, the Shelly is not reachable under the previous IP (.31), so something was “cleaned”, removed.
Than I flash the Shelly again, now with IP .32 (in my_user_config.h changed from .31 to .32 and save, build).
But the Shelly is still reachable after the old IP .31 as before ! And still the Web-password is requested, why??
