I have Shelly1 devices, and the parameter, “Reverse inputs - If you enable this option, the buttons On/Off position will be inverted.” is getting set when OH reloads rules.
I browsed the Github repo, and don’t see where in the API this is getting set. Is there a way to configure this like the AutoOn channel?
This is on OH2.5, using the Shelly binding.
Current firmware version: v1.5.7/20191216-090109(c30657ba)
