because I just received my Shelly1PM (Power Metering) shipment, I wanted to add them via MQTT to my openHAB. Unfortunately, the official API documentation is not up to date right now. https://shelly-api-docs.shelly.cloud/
So I poked around and it took me some time but I managed to get the information through MQTTLens so that I can hopefully help someout out there who doesn’t want to dig for this information.
The Shelly1PM publishes the following information to the Broker:
shellies/shelly1pm-/relay/0/power
Power-Reading as Number
shellies/shelly1pm-/relay/0/energy
Energy-Reading as Number
shellies/shelly1pm-/temperature
Internal Temperature as Number
shellies/shelly1pm-/overtemperature
Overtemperature-Warning as Number (0 and 1)
Switch-Status as String
As of now I could not properly figure out how to toggle the switch-status. The Shelly v1 requires lowercase “on” and “off” as strings published to it but this 1PM doesn’t seem to like that. Maybe someone has it working and can chime in on this one?
The overtemp-information can be redirected into a Switch-Command. You only need to add the custom_on and custom_off values in PaperUI when you set the Channel up.
Hope this helps someone out in order to get their setup working.
Edit: Corrected the temperature and overtemperature strings accordingly.
Ah yes - sorry that was my bad. I forgot to edit the pasted lines here. Yes it is on the device level and not under relay.
For the toggle-switch: I tried it with the /command just like my shelly v1 and send an on or off but it doesn’t like that.
Right now I don’t want to mess with it because the attached dishwasher is running. Will update this thread if I find something new
I tried to replicate the command of the shelly1 for the shelly1pm using:
shellies/shelly1pm-xxxxxx/relay/0/command with on and off commands but it’s not working.
Not sure if this is going to solve it (I do not use textual configuration for MQTT), but your Thing definition has 1PM while the item has 1pm as channel name. Might very well be case sensitive.
