Shock sensor not reporting alarm_access
Using Openhab2.3 on Windows 10.
sometime after upgrade from 2.2 to 2.3 vision shock sensor (ZS5101) is not reporting alarm_access anymore - nothing in logs. connectivity still exists, but no reporting of any movement.
I have two sensors, both behaving the same. tried reinitializing and healing them - didn’t help/
Any idea?
https://www.openhab.org/addons/bindings/zwave/thing.html?thingTypeUID=vision_zs5101_00_000
Did it work after upgrade to 2.3?
I don’t know for sure, as I noticed that only some time after the upgrade. it did work before the upgrade, that’s for sure.
Check and post the Things and Control in PaperUI please.
zwave_class_basic BASIC_TYPE_ROUTING_SLAVE
zwave_class_generic GENERIC_TYPE_SENSOR_NOTIFICATION
zwave_neighbours 1,2,3,6,9,10
zwave_lastwakeup 2018-09-12T03:16:55Z
modelId ZS5101
zwave_version 16.6
zwave_plus_devicetype NODE_TYPE_ZWAVEPLUS_NODE
vendor Vision Security
defaultAssociations 1
zwave_routing true
zwave_beaming true
zwave_secure false
zwave_class_specific SPECIFIC_TYPE_NOTIFICATION_SENSOR
zwave_devicetype 8195
zwave_frequent false
zwave_listening false
manufacturerId 0109
manufacturerRef 2003:0306,2003:0307
dbReference 442
zwave_deviceid 775
zwave_nodeid 11
zwave_lastheal 2018-09-10T07:26:32Z
zwave_plus_roletype ROLE_TYPE_SLAVE_SLEEPING_REPORTING
zwave_manufacturer 265
Channels
radio_button_checked
Binary Sensor
zwave:device:f42480b1:node11:sensor_binary
Switch
Shock Alarm
zwave:device:f42480b1:node11:alarm_access
Switch
Tamper Alarm
zwave:device:f42480b1:node11:alarm_tamper
Switch
Battery Level
zwave:device:f42480b1:node11:battery-level
Number
Node 011: Shock Sensor Mamad
launch
radio_button_unchecked Binary Sensor
radio_button_unchecked Shock Alarm
radio_button_unchecked Tamper Alarm
trending_up Battery Level
