Shown versions in openhab-cli info and in WebGUI are different after update
My system:
Raspberry Pi 4, 8GB
Linux Ubuntu 20.04 LTS
Java 17
over the weekend I migrated my OpenHAB system from version 3.4.4 to the current version.
Interesting fact is that when I tried to install the InfluxDB persistence binding the GUI showed 3.4.4 which was my old version. I also checked this in the Main GUI on the bottom left in the menu “Help & About”.
On the other hand running the CLI openhab-cli info was showing version 4.2.2.
Apparently the GUI does not know that I made an update.
And maybe because of this I was not able to install the InfluxDB driver, maybe because of a mismatch of versions.
Do you have a hint for me?
Thanks in advance.
Wolfgang
I found the solution myself.
I needed to clear the cache and after doing so the versions shown in the GUI and in CLI are identical.
I will close this topic now and mark it as solved.
