I don’t know how to do that with the data from tasmota console
HALF button 3 does not work, because I do not know how to set ( Shutter position 40)
I’m very happy if you help me with the syntax
I have the trasformation service installed
I made the change like you said, but it doesn’t work.
Maybe I’m not properly explaining what I need.
I set the Tasmota UP 13s & DOWD 13s works fine, and works fine in OH as well.
My problem is how to set a position 50 shutter {half} from UP OR DOWN
Change stat to tele in the stateTopic and see if that will give the shutter %.
Example:
Type switch : ch10 "Power" [ stateTopic="tele/
From the tasmota console can you send the command for a certain % and have the shutter move to the correct position? If so please post the command example used.
