Signal Binding [5.2.1.0;6.0.0.0)
Sincere thanks for the investigation !
I push new versions to jfrog manually. I will push 0.14.5 this evening.
I build them on my fork with github actions, because signal-cli doesn’t provide graalvm binaries for architecture other than linux x64. I also have to take the right libsignal version from another repository and upload them alongside. I should document this ASAP.
By the way, I don’t know if I can fully automate this… Ideally a new tag on signal-cli upstream would trigger my custom build, get the right libsignal and upload results to jfrog. Not a one liner though :smiling_face_with_tear:.
Great ! Can you please provide me some details ? Main ones are, does it download signal-cli automatically, and does it run ? I would gladly appreciate any other informations :+1:
Thanks for the report. Indeed your system is old.
But on my side, there is an issue: the error messages are not good enough. I will add it to the pile of things to do.
Today, I tried sending a message from my smartphone to my openHAB Signal account. In the process, I received the error messages listed below.
Two while entering the message in the existing chat on the smartphone, and the third after sending it.
Sending messages from openHAB to the smartphone is possible.
2026-06-15 15:26:10.828 [WARN ] [service.JsonRpcAbstractSignalService] - Cannot parse recipient address from source null and uuid null
2026-06-15 15:26:14.880 [WARN ] [service.JsonRpcAbstractSignalService] - Cannot parse recipient address from source null and uuid null
2026-06-15 15:26:23.583 [WARN ] [service.JsonRpcAbstractSignalService] - Cannot parse recipient address from source null and uuid null
openHAB-version: 5.1.4
Thing-account configuration:
version: 1
things:
signal:signalaccountbridge:9f7b6d735b:
isBridge: true
deviceName: openHAB
phoneNumber: "+4929xx12345"
enableReaction: false
channels:
receivetrigger:
type: signalreceivetrigger
Item definition:
  signalReceivedMessage_OpenHAB:
    type: String
    label: Signal Account Message Received
    tags:
      - Point
    channels:
      signal:signalaccountbridge:9f7b6d735b:receivetrigger:
        profile: system:trigger-event-string
See All incoming sealed-sender messages dropped: NullPointerException getServerGuid(...) must not be null (0.14.2 and 0.14.4.1) · Issue #2059 · AsamK/signal-cli · GitHub
Thank you for the information. So I will wait.
The new signal-cli version is available. I emphasize “signal-cli”, not signal binding.
So, the process is NOT the usual one ! This time, the binding version DOES NOT change. You don’t have to remove/reinstall the binding in the marketplace.
The only change is the signal-cli version to use. If you are on “local” or “network” kind, it is on you. You have to manually set up/install the new version.
If you are on the “managed” kind, you have to set, in the signal binding configuration page, the
“Kind-Related Configuration Parameter” with the following version:
0.14.5
And save.
The binding will download the new version. This new version fixes the error when receiving messages.
EDIT : Probably nothing, but I had a misfire when testing the download process on my system. The log told me that the binding could not resolve some google storage related server name (jfrog hosting). Stopping and restarting the thing forced the binding to try again, and this time it worked. Please tell me if you have issues.
:clap: it perfecly works, without disable/enable the thing,
only change the “Kind-Related Configuration Parameter” from auto to 0.14.5
Many thanks for your great work.
Same thing here on my raspberry - it worked including download in managed environment
Dear Dalgwen,
i know now what the difference is: we talk about different UUID.
As i restored my signal installation somehow manually during your upgrade, i added the user accounts (signal:signalconversation) also manually. The accounts get a new UUID from openhab (signal:signalconversation:874XXXXdae:169dXXXXe7). I tried to send to his UUID a message. this didn’t work.
You are talking about the signal UUID (or ACI). This i find with my manually added accounts nowhere. I found it in an old rule and tested - it worked. I am able to send to this UUID a message. But without my old rule as source, i found no way to get the ACI.
Long story short: you made a great job.
Thx & best regards
Christian
I want to change my profilename and my avatar, but in the Action “Update Profile” is no input field. Is changing not possible?
Thing Type is Signal Account (This bridge represents a Signal account with a dedicated number.)
It is not possible for the moment. The action is here to update to the default name (“OpenHAB” if I remember ?) + icon, if it didn’t work during the setup.
(Of course, it’s only for the dedicated number account type).
Maybe it shouldn’t be an action, but a parameter. But in this case I’m not sure when the update should occur. I will think about it and may be able to put it in the next release. (But as usual, for fellow developers : PR welcome to go faster :wink: )
Here is an PR (hopefully correct :roll_eyes:)
Thank you very much for the quick reply and the considerable time you are investing.
Hello, thanks for your effort, but I think there is a misunderstanding :sweat_smile:
A PR is a “Pull Request”, it is a contribution to the code or documentation. The best code is the code I don’t have to do, so I’m always hoping for fellow dev to replace me !
Anyway, I made a new version, mainly to update the default signal-cli version, but I also managed to upgrade the update action : now we are able to change the name and profile picture (use a path to a local file on your disk. You don’t have to keep the file on your disk, as it is uploaded to the signal service).
Just to let you know that I finally got to upgrade my OS and everything is working as far as I could test it. Thanks for your work!
